Mstar mw8533d not read HELLO I GET PHONE WITH MSTAR MW8533D CPU HANG ON LOGO I TRY UNSUCCESSFULLY TO READ IT BEFORE TO FOR%AT I GET THIS SCREENSHOT PLEASE HELP ME TO SOLVE THIS PROBLEM http://s11.postimg.org/5demoyigj/ARM_MW8533_D_png2.png |
Try on default boot Br;) AzimBahar |
select default boot your problem will be solved BR Qaisar Mahmood |
@ akeal81 .... Use Modify Cable .. http://forum.gsmhosting.com/vbb/9347474-post1.html If you Use this Cable for Mstar Chip .. No Need Any Power or Buttery .. Just Plug the Cable .. Or You Can use Also Volcano Main Cable .. First Connect the Jig Correctly & Install Mstar Driver Properly .. Use Default Boot No need to change Baud rate .. Select Read/Write & Do Run .. If you Get Any Error ... Use Volcano low Version & Post Result ... Br, AniAXN;) |
