Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 12-24-2014, 11:24   #1 (permalink)
Member: 1263652
Thanks Meter: 42
HELP ME to connect sfr132 to volcano
sfr 132 mt6252 ; how to conect it to volcano box???
Old 12-24-2014, 11:40   #2 (permalink)
Member: 2207555
Thanks Meter: 1,622
  • dessemble mobile
  • sold rx tx.
  • connect with volcano with
  • tick mark auto detect.
br
rehan shaikh.
The Following User Says Thank You to rehansk8879 For This Useful Post:
Old 12-24-2014, 11:44   #3 (permalink)
Member: 2207555
Thanks Meter: 1,622
USB MODE:
1- Put Mobile into FTM mode
How to enter FTM mode?
A: Power off phone
B: take Battery off
C: Insert Battery
D: Press & Hold Volume down and Power button Together till mobile comes into FTM mode
2- After FTM mode insert Original USB cable in mobile
3- Install Drivers ( Drivers can found from install folder Drivers\Zte Unlock Drivers\ZTE_Handset_USB_Driver)
4- In device manager you can see installed Com port of ZTE phone with name “ Zte handset diagnostic interface (DFU) “
5- Open VolcanoBox software
6- Go to Zte Tab
7- Select Com port of Zte handset diagnostic interface (DFU)
AND DO YOUR OPERATION.
Old 12-24-2014, 11:58   #4 (permalink)
Member: 2207555
Thanks Meter: 1,622
HERE IS THE RX TX PINOUT:
REHAN SHAIKH
Old 12-24-2014, 13:55   #5 (permalink)
Member: 1263652
Thanks Meter: 42
than you ..! so I use the rj45 cable?? I don't know work with volcano tool for this modele??? help me please
Old 12-24-2014, 16:24   #6 (permalink)
Member: 1263652
Thanks Meter: 42
I soldered tx an rx but no connect
Old 12-24-2014, 17:31   #7 (permalink)
Member: 1263652
Thanks Meter: 42
 Detection initiated, connect the phone and power on it...
  Vcc: null
  Gnd: null
  Analyzing Rx and Tx...
  Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient...
  Failed to detect.
>>Pinouts are not fonud!
Old 12-24-2014, 17:45   #8 (permalink)
Member: 1263652
Thanks Meter: 42
Old 12-24-2014, 18:22   #9 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Hello ...
Can you plz change battery negative or positive points ...
& Try again on that way ...
Wbr,
AniAXN
The Following User Says Thank You to AniAxn For This Useful Post:
Old 12-24-2014, 18:58   #10 (permalink)
Member: 1263652
Thanks Meter: 42
same problem i can't read info
Page generated in 0.15019 seconds with 8 queries
