03-02-2016, 15:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | MT6592 flash via Rx tx method in request. [ Answered ] |
03-02-2016, 15:47 | #2 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Quote:
Android MTK SMARTPHONE IS CONNECT BY SOLDERING RX TX,YOU HAVE TO FLASH IT VIA USB PORT... Regards Rehan Shaikh | |
03-02-2016, 15:50 | #3 (permalink) |
Member: 2500215 Status: Offline Thanks Meter: 417 | Thanks a million. When it is connected, will it go to the box? If yes, will merapi or sp flash tool recognise it? If no. Can you explain a little bit please? |
03-02-2016, 16:32 | #6 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
1 -Red wire on Vbus point that is charging point 2-Black on gnd 3-Green on Dm/D+ 4-Blue or white on Dp /D- if not work change green to the point of blue and blue to green hope you will succeed. | |
The Following 5 Users Say Thank You to amn32 For This Useful Post: |
03-02-2016, 18:26 | #11 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
yes you can write firmware and I can help you to write firmware via rx tx. But you need minimum 1day (24 hours) or 2 or even more depend on firmware size | |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
03-02-2016, 18:28 | #12 (permalink) |
Member: 2500215 Status: Offline Thanks Meter: 417 | Oops. That means the write speed is extremely slow. The firmware size is 1.9GB. Lollipop 5.1 Sent from my TECNO_P5_PLUS using Tapatalk |
03-02-2016, 18:54 | #13 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | yes you need aprox 4 days to transfer this size via rx tx. but you are lucky you have usb (DP DM) over the board so you can transfer via usb high speed within minutes. |
The Following 4 Users Say Thank You to Nasir Mobiles For This Useful Post: |
03-06-2017, 06:16 | #14 (permalink) |
Junior Member Join Date: May 2016 Location: Pakistan punjab sargodha Age: 33
Member: 2574933 Status: Offline Thanks Meter: 5 | Assalamoalikum bhai if dm and dp points not work then what i do how to fix it please any one give me answr of this question please it is request. i have qmobile v2 via usb jeck not connect to pc but i try to connect via dp/dm points and vcc gnd but not recognize please any body help me |
03-06-2017, 07:16 | #15 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: India
Member: 2030192 Status: Offline Thanks Meter: 1,334 | Quote:
If its Spd based mobile then short boot/tx to gnd then try | |
