Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 03-05-2013, 14:00   #1 (permalink)
Registered User
Member: 1738183
Sonork: technominds
Thanks Meter: 22
CPU TPYE : Gallite series when it will support by Volcano?
Detection initiated, connect the phone and power on it...
Vcc: 10
Gnd: 1 4
RX: 6, TX: 7
please press Power on/off button...
kmaxmax
Old 03-05-2013, 14:41   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Vcc: 10
Gnd: 1 4
RX: 6, TX: 7
kmaxmax
Some Time Show This Cpu Name It's Mean Phone Not Connected Properly OR Select Boot-B With Auto Flash Type It's Better OR Hardware Issue.
BR.
Arsalan gsm2000.
Old 03-05-2013, 14:44   #3 (permalink)
Member: 791635
Sonork: 100.1611665
Thanks Meter: 30
use VolcanoBox 1.8.5 your problem will solve.
OR..WAIT FOR NEXT UPDATES.....
Old 03-05-2013, 16:36   #4 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
@ .::mastech::.
always give full details about your problem
about your mobile status
br,
azam
Old 06-17-2013, 11:37   #5 (permalink)
motursa's Avatar
Member: 112034
Thanks Meter: 59
solution
Quite possibly you are trying to read a phone, SPD within the MTK tab, select SPD or vice versa
Old 06-17-2013, 11:53   #6 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
gallite series is RDA.supported by volcano!check boot B
Old 06-17-2013, 12:43   #7 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
BR.
Arsalan gsm2000.
100% u r right man some time we not connect accurate change jig direction than check
Old 06-17-2013, 13:18   #8 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
It's coolsand CPU inside the phone
Try sold rx tx and post result
And phone condition
Old 09-10-2013, 07:57   #9 (permalink)
Member: 975148
Sonork: 100.1656811
Thanks Meter: 21
Volcano Updated: 2013-09-06
Connecting...
Connection successful,connected state!
Version: V3.8
SN:
Port:COM3
After format or Flash you have to press & hold power button for at least 1.30 mins.
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
Available Ports:COM1 COM3
Vcc: null
Gnd: null
RX: 3, TX: 4
Not download boot file.
Flash_size:0x400000
IMEI1:354758052930703
IMEI2:354758052930711
IMEI3:354758052930703
>>IMEI4:354758052930703
any solution
Old 09-10-2013, 12:23   #10 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
Connecting...
Version: V3.8
SN:
Port:COM3
Vcc: null
Gnd: null
RX: 3, TX: 4
Flash_size:0x400000
any solution
what condition and problem of phone
Old 11-12-2013, 11:47   #11 (permalink)
Crazy Poster
Member: 890902
Thanks Meter: 8
Vcc: null
Gnd: 16
RX: 14, TX: 24
help me
Old 11-12-2013, 20:55   #12 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
Originally Posted by ashif0786 View Post
Vcc: null
Gnd: 16
RX: 14, TX: 24
help me
what condition of your phone , if dead then better check in hardware please
Old 11-26-2013, 20:37   #13 (permalink)
Member: 1115995
Thanks Meter: 7
Same problem happened to me... After 2days of trying with the jig, old software version, etc. i soldered rx, tx, gnd, and vcc directly. And after 5 or 6 tries it could be done... Some thing wrong with coolsand and volcano?
2013-11-26 21:16:29 >>Vcc: 3
2013-11-26 21:16:29 >>Gnd: 7
2013-11-26 21:16:29 >>RX: 15, TX: 11
2013-11-26 21:16:29 >>Detection completed with 12,14 seconds!
2013-11-26 21:16:33 >>Setting pinouts...
2013-11-26 21:16:35 >>Pinout setting complete.
2013-11-26 21:17:40 >>Available Ports:COM4
2013-11-26 21:17:40 Port: COM4
2013-11-26 21:17:40 Baud rate: 921600
2013-11-26 21:17:40 Flash size: A u t o
2013-11-26 21:17:40 Start Address: Auto
2013-11-26 21:17:40 Boot: Built-in BOOT_B
2013-11-26 21:17:40 Usb mode: False
2013-11-26 21:17:40 IMEI1: 35906*********
2013-11-26 21:17:40 IMEI2: 35906*********
2013-11-26 21:17:40 operation: Write IMEI
2013-11-26 21:17:41 >>Start program...
2013-11-26 21:17:46 >>CPU ID: 8801 4006
2013-11-26 21:17:46 >>Flash ID : 00C22537
2013-11-26 21:17:46 >>Flash Type: SF_MX25U6435E
2013-11-26 21:17:46 >>Flash Len :0x800000(8M)
Volcano stop process here... Then try
2013-11-26 21:18:00 Port: COM4
2013-11-26 21:18:00 Baud rate: 921600
2013-11-26 21:18:00 Flash size: A u t o
2013-11-26 21:18:00 Start Address: MX25U6435E
2013-11-26 21:18:00 Boot: Built-in BOOT_B
2013-11-26 21:18:00 Usb mode: False
2013-11-26 21:18:00 IMEI1: 35906*********
2013-11-26 21:18:00 IMEI2: 35906*********
2013-11-26 21:18:00 operation: Write IMEI
2013-11-26 21:18:01 >>Start program...
2013-11-26 21:18:04 >>CPU ID: 8809 4006
2013-11-26 21:18:17 Port: COM4
2013-11-26 21:18:17 Baud rate: 921600
2013-11-26 21:18:17 Flash size: A u t o
2013-11-26 21:18:17 Start Address: MX25U6435E
2013-11-26 21:18:17 Boot: Built-in BOOT_B
2013-11-26 21:18:17 Usb mode: False
2013-11-26 21:18:17 operation: Read Info
2013-11-26 21:18:18 >>Start program...
2013-11-26 21:18:21 >>CPU ID: 8809 4006
2013-11-26 21:18:23 >>Flash ID : 00C22537
2013-11-26 21:18:23 >>Flash Type: SF_MX25U6435E
2013-11-26 21:18:23 >>Flash Len :0x800000(8M)
2013-11-26 21:18:48 Port: COM4
2013-11-26 21:18:48 Baud rate: 921600
2013-11-26 21:18:48 Flash size: A u t o
2013-11-26 21:18:48 Start Address: Auto
2013-11-26 21:18:48 Boot: Built-in Auto
2013-11-26 21:18:48 Usb mode: False
2013-11-26 21:18:48 operation: Read Info
2013-11-26 21:18:49 >>Start program...
2013-11-26 21:18:51 >>CPU ID: 8809 4006
2013-11-26 21:19:00 Port: COM4
2013-11-26 21:19:00 Baud rate: 921600
2013-11-26 21:19:00 Flash size: A u t o
2013-11-26 21:19:00 Start Address: Auto
2013-11-26 21:19:00 Boot: Built-in BOOT_B
2013-11-26 21:19:00 Usb mode: False
2013-11-26 21:19:00 IMEI1: 35906*********
2013-11-26 21:19:00 IMEI2: 35906*********
2013-11-26 21:19:00 operation: Write IMEI
2013-11-26 21:19:02 >>Start program...
Volcano TERMINATED here... Then try
2013-11-26 21:20:08 >>Volcano Updated: 2013-11-08
2013-11-26 21:20:09 >>Connecting...
2013-11-26 21:20:13 >>Connection successful,connected state!
2013-11-26 21:20:13 >>Version: V3.8
2013-11-26 21:20:13 >>SN:134-618-435
2013-11-26 21:20:13 >>Port:COM4
2013-11-26 21:20:14 >>After format or Flash you have to press & hold power button for at least 1.30 mins.
2013-11-26 21:20:14 >>Note for win7 users :
2013-11-26 21:20:14 >>Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
2013-11-26 21:20:14 >>After that the spd drivers will have the ability to be loaded.
2013-11-26 21:20:23 >>Detecting rx and tx...
2013-11-26 21:20:36 >>Vcc: 3
2013-11-26 21:20:36 >>Gnd: 7
2013-11-26 21:20:36 >>RX: 15, TX: 11
2013-11-26 21:20:36 >>Detection completed with 12,97 seconds!
2013-11-26 21:20:40 >>Setting pinouts...
2013-11-26 21:20:42 >>Pinout setting complete.
2013-11-26 21:20:58 >>Available Ports:COM4
2013-11-26 21:20:58 >>Detection initiated, connect the phone and power on it...
2013-11-26 21:21:11 >>Vcc: 3
2013-11-26 21:21:11 >>Gnd: 7
2013-11-26 21:21:11 >>RX: 15, TX: 11
2013-11-26 21:21:11 Port: COM4
2013-11-26 21:21:11 Baud rate: 921600
2013-11-26 21:21:11 Flash size: A u t o
2013-11-26 21:21:11 Start Address: Auto
2013-11-26 21:21:11 Boot: Built-in BOOT_B
2013-11-26 21:21:11 Usb mode: False
2013-11-26 21:21:11 IMEI1: 35906*********
2013-11-26 21:21:11 IMEI2: 35906*********
2013-11-26 21:21:11 operation: Write IMEI
2013-11-26 21:21:12 >>Start program...
2013-11-26 21:21:19 >>CPU TPYE : Gallite series
Volcano stop process here again... Then try
2013-11-26 21:22:02 >>Setting pinouts...
2013-11-26 21:22:05 >>Pinout setting complete.
2013-11-26 21:22:10 Port: COM4
2013-11-26 21:22:10 Baud rate: 921600
2013-11-26 21:22:10 Flash size: A u t o
2013-11-26 21:22:10 Start Address: Auto
2013-11-26 21:22:10 Boot: Built-in BOOT_B
2013-11-26 21:22:10 Usb mode: False
2013-11-26 21:22:10 IMEI1: 359068********
2013-11-26 21:22:10 IMEI2: 359068********
2013-11-26 21:22:10 operation: Write IMEI
2013-11-26 21:22:11 >>Start program...
2013-11-26 21:22:16 >>CPU ID: 8809 4006
2013-11-26 21:22:16 >>Flash ID : 00C22537
2013-11-26 21:22:16 >>Flash Type: SF_MX25U6435E
2013-11-26 21:22:16 >>Flash Len :0x800000(8M)
2013-11-26 21:22:17 >>Boot downloading...
2013-11-26 21:22:19 >>Change imei finish.
SUCCESS ... I changed nothing, same box, same solder, same set, detected different CPUs... It takes two days to change the imeis?
Page generated in 0.27011 seconds with 8 queries
