need help about mt 6572 cup |
What is problem in your mobile ? What do you want to do ? |
pattren lock bro ......... only |
First of All Check May be usb debug is on if on then Go to android tab then ADB & Wipe if off then try to put your mobile in recovery mood or Factory mood , if you can go in recovery then do wipe data in recovery menu , if you can go to Factory mood then root with Vroot after root Again in factory mood then wipe in Android > ADB tab>Wipe . |
and thanks for the reply.. ?? |
if usb debug is on then 1 > connect your mobile on usb cable 2 > install driver 3 > open Volcano software go to Android Tab then ADB tab 4 > root your mobile in adb tab 5 > wipe data in factory mood you can see option like this http://www.mediafire.com/convkey/8c0...c794o2qxzg.jpg option can be different from picture if you have clear flash option then just clear flash & done you can get factory or recovery mood by below method Press and hold volume down then press power button Press & hold volume up then press power button Press & hold volume down & up together then press power button you can try by pressing all buttons with power button . |
