01-28-2018, 09:45 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | E5573cs-609 unlock problem help Code: Found modem : E5573Cs-609 Model : Huawei AuthVer 4 modem (New) IMEI : Serial NR. : 5LL7S17401007664 Firmware : 21.323.01.01.274 Dashboard version : WEBUI_17.100.15.09.274_MRE5 Web UI version : WEBUI_17.100.15.09.274_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) =================== >Modem Info: >> Modem : E5573Cs-609 >> Manufacturer : huawei >> Firmware Ver. : 21.323.01.01.274 >> IMEI : >> SN. : 5LL7S17401007664 >> IsoVer. : WEBUI_17.100.15.09.274_MRE5 >> WebUiVer. : WEBUI_17.100.15.09.274_MRE5 >> Sim Card Status : Locked >> Wrong Codes Counter : 0 (left : 10) >> >>Modem Info Saved Path: C:\OtherTools\UniTool_Vol_EXT\ModemInfo\huawei_E5573Cs-609_2018-01-28 16_28_31 >>Ver:1.5.0 >>Current Task: HUAWEI>>Huawei Modem>>Erase >> >>Model: E5573cs-609 >>Firmware Ver: 21.323.xx.xx.274 >>COMPort: 56 >> Modem Files prepare Finished. Erase Successfully! ====================== >>Ver:1.5.0 >>Current Task: HUAWEI>>Huawei Modem>>Patch Flash >> >>Model: E5573cs-609 >>Firmware Ver: 21.323.xx.xx.274 >>COMPort: 56 >> Modem Files prepare Finished. Patch Flash Successfully! ======================== after that procedure log is. Code: Found Applications port COM99 Found modem : E5573Cs-609 Model : Huawei AuthVer 4 modem (New) IMEI : 861350032731157 Serial NR. : 5LL7S17401007664 Firmware : 21.323.01.01.274 Dashboard version : WEBUI_17.100.15.09.274_MRE5 Web UI version : WEBUI_17.100.15.09.274_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) =================================================================== at^nvwrex=8268,0,12,1,0,0,0,2,0,0,0, a, 0,0,0 ERROR any help?? |
01-29-2018, 09:59 | #2 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | i am waiting for some kind reply from team. but still no reply is there going wrong anything? if no then should be guide for further procedure. |
