02-26-2013, 13:02 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: Jessore, Bangladesh
Member: 1752997 Status: Offline Sonork: 100.1623316 Thanks Meter: 11 | problem with mstar cpu |
02-26-2013, 15:50 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | @ Mohammad Sumon work with usb cable Note: Use original USB cable Go to MSTAR Tab Untick Auto-detect pinouts (compulsory) Click On Read Flash or which want Power off your phone Insert USB cable to phone while pressing Boot Key (How to Find Boot Key) It will ask drivers install drivers (from C:\Program Files\Volcano Team\VolcanoBox\Drivers\Phone Drivers\Mstar) Now select Your Mstar USB com port ( it will detect auto in Volcano Box Mstar tab but check if its not then select manually ) Now its ready just click on Run Button Tips: Always post volcano screenshot br, |
02-26-2013, 17:12 | #4 (permalink) | |
Member: 1752997 Status: Offline Sonork: 100.1623316 Thanks Meter: 11 | Quote:
02-26-2013, 17:37 | #7 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | now you need find vcc pin ,search it with meter or find charging pin in detect tab or try first pin as vcc after set vcc select mstar pinfinding press detect button and keep press power button after usb pin find click set pins button now leave the power button go in mstar tab untick mark detect-auto pinouts do what you want |
02-27-2013, 08:13 | #8 (permalink) | |
02-28-2013, 05:51 | #9 (permalink) | |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Quote:
Do this now you need find vcc pin ,search it with meter or find charging pin in detect tab or try first pin as vcc after set vcc select mstar pinfinding press detect button and keep press power button after usb pin find click set pins button now leave the power button go in mstar tab untick mark detect-auto pinouts do what you want | |
