11-08-2015, 10:37 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Q A115 after write tested flash file dead. 14:10:48 > Merapi Updated: 2015-10-31 14:10:49 > Connecting... 14:10:51 > Connection successful,connected state! 14:10:51 > Version: V3.8 14:10:51 > SN: 000-000-323 14:10:56 > Connecting to server... 14:11:00 > Connecting to server...OK! 14:11:00 > Getting function information from server... 14:11:01 > Getting function information from server...OK! 14:11:19 > Access to functional permissions from server... 14:11:20 > Access to functional permissions from server...OK! 14:11:20 > 14:11:20 > 14:11:20 > >>Analysis of USB port,Please insert phone USB cable. 14:11:25 > Connecting... 14:11:25 > CPU TYPE:MT6572 14:11:25 > Hardware version:CA01 14:11:25 > Software version:0000 14:11:25 > SecCfgVal :0x00000000 14:11:25 > BromVersion :0xFF 14:11:25 > BLVersion :0x01 >>Boot downloading complete! 14:11:32 > FlashID:009800BC00900066 14:11:32 > Flash Type: NAND_TYBC0A111236KC10 14:11:32 > FlashLen:20000000 14:11:32 > 14:11:44 > PRELOADER:>>addr:0x000000 --length:0x080000 14:11:44 > PRO_INFO:>>addr:0x080000 --length:0x100000 14:11:44 > NVRAM:>>addr:0x180000 --length:0x300000 14:11:44 > PROTECT_F:>>addr:0x480000 --length:0x300000 14:11:44 > PROTECT_S:>>addr:0x780000 --length:0x300000 14:11:44 > SECCFG:>>addr:0xA80000 --length:0x040000 14:11:44 > Read phone information success. 14:12:08 > Access to functional permissions from server... 14:12:09 > Access to functional permissions from server...OK! 14:12:10 > 14:12:10 > 14:12:10 > >>Analysis of USB port,Please insert phone USB cable. 14:12:16 > Connecting... 14:12:16 > CPU TYPE:MT6572 14:12:16 > Hardware version:CA01 14:12:16 > Software version:0000 14:12:16 > SecCfgVal :0x00000000 14:12:16 > BromVersion :0xFF 14:12:16 > BLVersion :0x01 >>Boot downloading complete! 14:12:22 > FlashID:009800BC00900066 14:12:22 > Flash Type: NAND_TYBC0A111236KC10 14:12:22 > FlashLen:20000000 >>NFB bootloader downloading... >>Flash writing complete. 14:14:39 > Access to functional permissions from server... 14:14:40 > Access to functional permissions from server...OK! 14:14:40 > 14:14:40 > 14:14:40 > >>Analysis of USB port,Please insert phone USB cable. 14:14:44 > Connecting... 14:14:44 > CPU TYPE:MT6572 14:14:44 > Hardware version:CA01 14:14:44 > Software version:0000 14:14:44 > SecCfgVal :0x00000000 14:14:44 > BromVersion :0x05 14:14:44 > BLVersion :0xFE >>Boot downloading complete! 14:14:51 > FlashID:009800BC00900066 14:14:51 > Flash Type: NAND_TYBC0A111236KC10 14:14:51 > FlashLen:20000000 14:14:51 > 14:15:24 > Access to functional permissions from server... 14:15:25 > Access to functional permissions from server...OK! 14:15:25 > 14:15:25 > 14:15:25 > >>Analysis of USB port,Please insert phone USB cable. 14:15:30 > Connecting... 14:15:30 > CPU TYPE:MT6572 14:15:30 > Hardware version:CA01 14:15:30 > Software version:0000 14:15:30 > SecCfgVal :0x00000000 14:15:30 > BromVersion :0x05 14:15:30 > BLVersion :0xFE >>Boot downloading complete! 14:15:37 > FlashID:009800BC00900066 14:15:37 > Flash Type: NAND_TYBC0A111236KC10 14:15:37 > FlashLen:20000000 14:15:37 > |
The Following User Says Thank You to sultan_ For This Useful Post: |
11-08-2015, 11:15 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | Here is Scatter File Try with Merapi or SP Flash Tool Q Mobile A115 Ok MT6572_Scatter By Lucky2010 |
11-08-2015, 11:16 | #3 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Write Good Factory File Then Press Power Button 2 Minutes till Phone Get Power On Br Real ASH Team GPG http://forum.gsmhosting.com/vbb/f723...-team-2009781/ |
11-09-2015, 08:08 | #4 (permalink) | |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Quote:
Code: Flash files count is :10 Action : Firmware update. Selected Acer: Liquid Z110 Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6572_S00 NAND: (4Gb+4096Mb) [TOSHIBA] TYBC0A111557KC BOOT STYLE : NAND BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : MediaTek DA USB VCOM (Android) (COM17) Error FlashTool Download: S_DA_EMMC_FLASH_NOT_FOUND After flash this firmware need to perform some aditional steps 1.Reinsert battery, keep VOL- and power on untill phone will come in factory mode 2.Select line EMMC, and after press home button. 3.Wait untill phone will restart and will stuck on logo(leave for 1 min in this stage). 4.If phone not power on, reinsert battery and perform direct unlock. If repair fail, please contact us or report in forum to provide help. Wait untill phone will start charging. All done. | |
11-09-2015, 08:15 | #5 (permalink) | |
now phone is in dead condition. | |
11-09-2015, 08:19 | #6 (permalink) | |
Member: 1445819 Status: Offline Thanks Meter: 4,976 | Quote:
11-09-2015, 09:54 | #8 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Quote:
se latest sp tool load scatter go to format tab press Ctrl+Alt+v >>>to enable advance mode press Ctrl+Alt+b >>>> to enable nand bad blocks mode then format whole flash after that now write good firmware with merapi tool post result BR | |
11-09-2015, 12:34 | #10 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan
Member: 444381 Status: Offline Sonork: 100.1604585 Thanks Meter: 31 | A115 mtk6572 nand 4.2.2 - Download - 4shared - YMS-RYK2 RYK download this file and write 100% tested file.... |
11-10-2015, 06:56 | #11 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | WRITING ERROR WHOLE FLASH FORMATE STILL WRITING ERROR HANG AT (NFB BOOTLOADER DOWNLOADING) Last edited by sultan_; 11-10-2015 at 07:02. |
