Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 07-08-2014, 16:07   #1 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 580
how to format Spd phones with Volcano.??
i can read flash file
but i cant format the phone with Gmail account pasword
any help
Old 07-08-2014, 16:23   #2 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
any help
go to spd tab select spd 6820/10 boot read info do format
Old 07-08-2014, 16:35   #3 (permalink)
Member: 3617
Thanks Meter: 580
i try to make format ..i can not
Old 07-08-2014, 16:43   #4 (permalink)
Member: 3617
Thanks Meter: 580
i use Volcano usb cable
failed to read info
The Following User Says Thank You to Unlocker AL For This Useful Post:
Old 07-08-2014, 17:24   #5 (permalink)
Member: 1497980
Thanks Meter: 1,266
failed to read info
its driver problem check drive and keep press boot key like vol- etc
Old 07-08-2014, 18:01   #6 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
U connect wrong side of main cable,,,,just change the main cable side
Qaisar mahmood
Old 07-08-2014, 18:59   #7 (permalink)
Member: 3617
Thanks Meter: 580
i try another side of main cable
the same problem
Old 07-08-2014, 19:01   #8 (permalink)
Member: 3617
Thanks Meter: 580
i think if i have driver problem i can read also flash
as you see in picture with normal cable usb presing volum- ..i do read flash
Old 07-08-2014, 23:43   #9 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
100% driver problem
Please install driver first then try
And post result
Old 07-09-2014, 10:34   #10 (permalink)
Member: 3617
Thanks Meter: 580
thx a lot
you are right..i change computer
install drivers
Format done
Page generated in 0.16392 seconds with 9 queries
