S6 Dead After format with inferno v1.0n [ Solved ] set was slow and hangs offen i did format set goes dead and i took backup before format but now backup also not writing here are logs 12:18:13 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 12:18:13 12:18:17 Connecting... 12:18:18 CPU TYPE:MT6571 12:18:18 Hardware version:CA00 12:18:18 Software version:0000 12:18:18 SecCfgVal :0x00000000 12:18:18 BromVersion :0xFF 12:18:18 BLVersion :0x01 12:18:19 Boot downloading... 12:18:24 FlashID:00AD00BC00900055 12:18:24 Flash Type: NAND_H8BCS0UN0MCR 12:18:24 FlashLen:20000000 12:18:24 12:18:24 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 12:18:24 PreLoader USB VCOM Port (COM9) 12:18:24 Finding partition. 12:18:45 Reading preloader.bin . 12:18:45 Reading lk.bin . 12:18:46 Reading boot.img . 12:18:50 Reading recovery.img . 12:18:54 Reading secro.img . 12:18:54 Reading logo.bin . 12:18:54 Reading system.img . 12:22:08 Reading userdata.img . 12:23:49 12:23:50 Android_Info.txt create success. 12:23:50 File save path:C:\Users\123\Desktop\MT6571-2016-10-24 15_18_45\ 12:32:05 after this when i try to write its own backup 12:32:33 Hardware version:CA00 12:32:33 Software version:0000 12:32:33 SecCfgVal :0x00000000 12:32:33 BromVersion :0xFF 12:32:33 BLVersion :0x01 12:32:34 Boot downloading... 12:32:39 FlashID:00AD00BC00900055 12:32:39 Flash Type: NAND_H8BCS0UN0MCR 12:32:39 FlashLen:20000000 12:32:39 12:32:39 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 12:32:39 PreLoader USB VCOM Port (COM41) 12:32:39 Finding partition. 12:33:08 Format range: Start Address: 0x1584000000000000,Format Length :0x9D80000 12:33:08 Flash erasing... 12:34:59 12:34:59 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 12:34:59 12:35:05 Connecting... 12:35:06 CPU TYPE:MT6571 12:35:06 Hardware version:CA00 12:35:06 Software version:0000 12:35:06 SecCfgVal :0x00000000 12:35:06 BromVersion :0x05 12:35:06 BLVersion :0xFE 12:35:07 Boot downloading... 12:35:13 FlashID:00AD00BC00900055 12:35:13 Flash Type: NAND_H8BCS0UN0MCR 12:35:13 FlashLen:20000000 12:35:13 12:35:13 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 12:35:13 MTK USB Port (COM44) 12:35:13 Phone Info: CPU:MT6571 Flash Type:NAND 12:35:13 Check Flash Type Success! 12:35:13 Check FlashID Failed! 12:35:17 Write factory file failed! ErrorCode:2 |
Bro Upload logs of during Format. It's backup after Format? |
12:32:05 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 12:32:05 12:32:11 Process is terminated 12:32:16 12:32:17 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 12:32:17 12:32:21 Process is terminated 12:32:26 12:32:26 Operation: 1. Power off the phone. 2. Please insert USB cable within 20 seconds. 12:32:26 12:32:32 Connecting... 12:32:33 CPU TYPE:MT6571 12:32:33 Hardware version:CA00 12:32:33 Software version:0000 12:32:33 SecCfgVal :0x00000000 12:32:33 BromVersion :0xFF 12:32:33 BLVersion :0x01 12:32:34 Boot downloading... 12:32:39 FlashID:00AD00BC00900055 12:32:39 Flash Type: NAND_H8BCS0UN0MCR 12:32:39 FlashLen:20000000 12:32:39 12:32:39 INT RAM: 5.31258MB SDRAM EXT RAM: 4.00391MB DRAM 12:32:39 PreLoader USB VCOM Port (COM41) 12:32:39 Finding partition. 12:33:08 Format range: Start Address: 0x1584000000000000,Format Length :0x9D80000 12:33:08 Flash erasing... 12:34:59 |
sir i took backup before format not after format Quote:
sir u can check logs and time...before format i took backup and after format set dead and now even not writing own backup file.pls tell me what i do now... |
I Can See Something Fishy in your log !! are you sure Your Press Auto Format or Erase all ? Code: Format range: Start Address: 0x1584000000000000,Format Length :0x9D80000 |
i Assume their is a Problem in Format Address , If Device Still on Your Hand then Plees Send me Full Read Info Log on That Device |
