02-09-2015, 07:25 | #1 (permalink) | ||
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | Supported DeviceTest Reports By Volcano Team Officially.Last Test On 25-05-2015 Quote:
PS:PLease Do not Post Here Anything.Will be deleted Without Answer.Its For Team Test Report's. BR Last edited by laxmi kamlesh; 02-09-2015 at 07:33. | ||
The Following 5 Users Say Thank You to laxmi kamlesh For This Useful Post: |
02-09-2015, 07:42 | #2 (permalink) | ||
Member: 1873645 Status: Offline Thanks Meter: 977 | This error Massage Will Come In MTK 6571 chip. Quote:
Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPEMT6571 Hardware versionCA00 Software version0000 Boot downloading complete Then Its need Proloader Driver For Detect Emmc and Nand Memory. Don't Say its Software Problem. BR | ||
The Following 2 Users Say Thank You to laxmi kamlesh For This Useful Post: |
02-10-2015, 13:55 | #3 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | Zen U5 Pattern Lock Done. Use volume down + power key for 30 seconds. Mobile Will Show FastBoot Mode. Quote:
02-10-2015, 16:34 | #4 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | World 1st Intex Slimzz Duoz Read Flash Done. CPU: MTK 6261 Support Opration: Read,Write,Format,Unlock,Read Privacy. Quote:
The Following User Says Thank You to laxmi kamlesh For This Useful Post: |
02-10-2015, 16:47 | #5 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | World 1st Spice M-5008n Done. CPU:MTK6261 Support Opration:Read,write,format,read privacy,read phone code,Unlock. Quote:
02-12-2015, 12:31 | #6 (permalink) | ||
Member: 1873645 Status: Offline Thanks Meter: 977 | Micromax A47_mtk 6572 Cpu:mtk 6572 Support Opration:read,write,format auto and customize,IMEI repair,Read Phone Password. Read Info Quote:
Format Quote:
02-12-2015, 14:22 | #7 (permalink) | |
Member: 1873645 Status: Offline Thanks Meter: 977 | Micromax A064. CPU:MTK 6571 EMMC Support Opration: Read ,write,Format auto and customize,Repair IMEI. Quote:
03-03-2015, 08:14 | #9 (permalink) |
Member: 1873645 Status: Offline Thanks Meter: 977 | This Post For THose Spd Mobile Which is Not Detecting. If you Have Spd 6531 device and can't detect via volcano and you don't know boot key and no have boot point on board. then open board and find TX pinout and short with GND. Then do your Job..its work like a Magic. [B]Note:upcomming 6531 Based Mobile TX point Can Be Found On Charging Jack Point 4 work as boot point. BR |
The Following 20 Users Say Thank You to laxmi kamlesh For This Useful Post: |
03-21-2015, 15:08 | #10 (permalink) |
Member: 1873645 Status: Offline Thanks Meter: 977 | New Flash ID Based Spd 6531 IMEI Restore Ways. There is new spreadtrum 6531 based mobile IMEI repair Function make very easy like 1,2,3. 1.turn of mobile. 2.insert usb and select diag port in volcano.press repair/write imei. Select diag port. In Device/Mobile you will See this Option.like Image. 3.what are you looking in 3rd option ? Time To do Something New. BR |
The Following 4 Users Say Thank You to laxmi kamlesh For This Useful Post: |
03-30-2015, 08:37 | #11 (permalink) | ||
Member: 1873645 Status: Offline Thanks Meter: 977 | We Have Unbeatable Feature For Repair IMEI In Spd Android We Have Unbeatable Feature For Repair IMEI In Spd Android. Hello To all. As My Title .Volcano Can Repair SPD android Imei Just in 3-5 Seconds. Note: 1.some mobile need to Disconnect Vcc Supply for repair IMEI. 2.SOme Mobile Don't Need TO Disconnect Vcc Supply. 3.No need to press Mobile Boot Key.when its repair imei. SOme Test Reports. A65 hang on logo done Quote:
The Following 10 Users Say Thank You to laxmi kamlesh For This Useful Post: |
05-25-2015, 19:46 | #12 (permalink) |
Member: 1873645 Status: Offline Thanks Meter: 977 | RDA 88X9CL Cpu Supported With Volcano. Hy Guys As Before I am Back With New CPu. World 1st !! Volcanobox Supported Coolsand (RDA) 88x9cl Cpu !! Rda Launch New Cpu called "88X9CL" Supported With Volcano. Cpu Image Volcano Read Flash. BR Kamlesh Lohar Last edited by Faisal_Computer; 05-26-2015 at 05:58. |
