spd 6820 not yet solved 100% 1 Attachment(s) i had some 6820 spd chip which is dead on software, now i write bin file, it was success but still dead. i notice that system file was not written while flashing, i make a pac file still stop at system. any solution east 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM12 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM64), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 240m(system),150m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic) Analysis flash internal data successfully. Set to Factory successfully. failed to open port. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM64), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 File partition was not found. Detection initiated... Failed to connect, please try again. Pinouts are not fonud! Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM64), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A Writing completed. Flash file E:\VOLCANO\spd\6616820\BIN\m-horse i9500\_20140103_103718_FullFlash.bin has been written. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM64), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A Writing completed. Flash file E:\VOLCANO\spd\6616820\BIN\m-horse i9500\_20140103_103718_FullFlash.bin has been written. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM64), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A Writing completed. Flash file E:\VOLCANO\spd\6616820\BIN\m-horse i9500\_20140103_103718_FullFlash.bin has been written. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. |
someone give respond on this im confused |
at this time spd 6820\8810 not fully supported any write bin result dead phone this original flash file ... 6820_2.3.5_c913_jhm_e08_v05_130626-E08T?¬?HV?+-130626-2P bro yzoo aden |
no solution on my phone yet still waiting 4 file anyone who have can give pls |
only pac file solve your problem br.. |
Volcano Updated: 2014-04-08 Connecting... Connection successful,connected state! Version: V3.8 SN:217-309-012 Port:COM94 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM3 COM94 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6,53 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SPRD U2S Diag (COM132), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),140m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic) Analysis flash internal data successfully. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6,06 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SPRD U2S Diag (COM132), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 Reading completed. Read time: 67 min 52 s The data has been saved in D:\VULKAN-FLESHEVI\9500mini- Flash Type[Hyundai] NAND_HY27UT088G2A\_20140416_234925_FullFlash.bin, size: 512 M. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6,31 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Set the Pinouts failed,please reconnect and try again! Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6,14 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SPRD U2S Diag (COM132), (VID_1782&PID_4D00) Pinouts setting complete! Temporary does not support this operation. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 6,30 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 4 Setting... Find USB device:SPRD U2S Diag (COM132), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 250m(system),140m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic) Analysis flash internal data successfully. Set to Factory successfully. failed to open port. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. failed to open port. Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. Detection initiated... Failed to detect VCC and GND, not connected to mobile phone or mobile phone is over-current. Pinouts are not fonud! Detection initiated... Failed to detect VCC and GND, not connected to mobile phone or mobile phone is over-current. Pinouts are not fonud! Detection initiated... bat noht posible wreit flesh :) D+ = 3, D- = 2 Analyzing USB device, please wait... Find USB device:SPRD U2S Diag (COM132), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 Please read the phone partition. >>Ready to read/write again, please remove the power supply clip or battery and then re-loaded it. |
yes fles file bekup noht posible to wreit eny ide :) |
[email protected] |
i still have m horse 920 mini , itel it450e, itel it1351, and techo p3 copy |
my problem soloved tnx for shering file wreit pack file working fine regards |
post the pac file here not bin file not read from volcan thanks.. |
stiel problem one sim working fine wied sim freez :) |
