volcano box problem Volcano Updated: 2013-02-26 Connecting... Connection successful,connected state! Version: V3.8 SN:120-535-571 Port:COM45 After format or Flash you have to press & hold power button for at least 1.30 mins. Available Ports:COM1 COM3 COM4 COM45 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 5 Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop >>Pinouts are not fonud! |
your mobile phone CPU Nama? |
what cpu inside ??? sold rx tx then try or find usb pin outs |
try with this method MTK USB Method go to detect tab select cpu type (D+ D-) MTK USB & Mstar (Do Find Boot) connect phone click detect button then click on set pinout now go back to mtk tab untick auto pinouts detect select operation you want (format. read flash. write flash. imei tools) and click run ( dont touch power button) try and post result with screen shot |
Sir try x285 Connecting... Connection successful,connected state! Version: V3.8 SN:120-535-571 Port:COM12 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. C:\VolcanoBox\PrtScn\PIC_2013_11_23_12_29_30_PM.jp g saved. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... Failed to detect. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... >>Failed to detect.but same problem |
full details bro? unit name: cpu? unit problem for us to easy to help about your inquery. |
i try to 10 mobile to format but no one is conneting to box these problem is coming plz help Connection successful,connected state! Version: V3.8 SN:120-535-571 Port:COM16 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Detecting rx and tx... Vcc: null Gnd: 5 Detection initiated, connect the phone and power on it... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop Available Ports:COM1 COM16 Detection initiated, connect the phone and power on it... Vcc: null Gnd: 5 Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop Pinouts are not fonud! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... Failed to detect. Detecting rx and tx... Vcc: null Gnd: 5 Detection initiated, connect the phone and power on it... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop Detection initiated, connect the phone and power on it... Vcc: null Gnd: 5 Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop Pinouts are not fonud! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 9 Gnd: 2 Detection initiated... User stop Detecting rx and tx... Vcc: 9 Gnd: 2 Detection initiated, connect the phone and power on it... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... User stop Detection initiated, connect the phone and power on it... Vcc: 9 Gnd: 2 Analyzing Rx and Tx... Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient... Failed to detect. >>Pinouts are not fonud! |
did You Tried With Rx, Tx ?? Also Change Main Vcc/Grnd Cable. open Volcano,Go To System > System Self Check & Click System Recovery. B,R. ;) |
problem solved http://forum.gsmhosting.com/vbb/f723...olved-1769355/ |
VCC or GND pins VCC or GND pins ka matlb or u kese set ho ge |
then first lean about mobile repairing then ask |
