10-01-2013, 10:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: IRAN
Member: 1222839 Status: Offline Sonork: 100.1603618 Thanks Meter: 3,944 | Samsung orginal i9082 4.2.2 root done with Father Of All Box Volcano :) Available Ports:COM1 COM7 COM84 COM85 Connection phone... Phone connection is successful. Root process may restart the phone several times, keep your phone and data lines connected correctly. Getting Root privileges, please wait... Phone Model: GT-I9082 Android Release: 4.2.2 >>Root Success,phone is restarted. BR, BEHBOODI |
The Following 4 Users Say Thank You to BEHBOODI For This Useful Post: |
12-11-2013, 08:35 | #5 (permalink) |
Junior Member Join Date: Mar 2013 Location: manila phillipines Age: 41
Member: 1902840 Status: Offline Thanks Meter: 0 | its working.. just wait for few seconds.. and the phone will restart for several times wait for the message "root success, phone is restarted" |
03-31-2014, 10:22 | #6 (permalink) |
Freak Poster Join Date: Jul 2009 Location: machilipatnam
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | how many minutes for rooting.??????? when i try rooting show this message Root process may restart the device several times, keep your device and data lines connected correctly. Getting Root privileges, please wait... Device Model: GT-I9082 Android Release: 4.2.2 Forced to disconnect from the phone by other similar software, turn off them, and re-start root. Connecting device... Device connection is successful. Root process may restart the device several times, keep your device and data lines connected correctly. Getting Root privileges, please wait... Device Model: GT-I9082 Android Release: 4.2.2 Forced to disconnect from the phone by other similar software, turn off them, and re-start root. What is the problem??????? |
04-07-2014, 14:06 | #7 (permalink) |
Member: 1080792 Status: Offline Sonork: 4d0ddc25d0db862fb2f2b62f1 Thanks Meter: 31 | gt-9082 is locked mobile. when i try to root this mobile with volcano shows this message. Root process may restart the device several times, keep your device and data lines connected correctly. Getting Root privileges, please wait... Device Model: GT-I9082 Android Release: 4.2.2 Forced to disconnect from the phone by other similar software, turn off them, and re-start root. Please expalin this problem |
04-11-2014, 12:55 | #8 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 893550 Status: Offline Thanks Meter: 139 | well... i download and installed it successfully ( os 4.2.2 jelly bean official ) now ... the problem rooting part >.< i success started odin and rooted the device as usual well ... odin says "pass" now ... when i try to enter CWM using ( volume+ and power key with home button ) -- my device screen goes black and it just restart again and then boot normally, cwm is not booting and stock is not booting aswell solution is below |
04-11-2014, 12:56 | #9 (permalink) | |
Member: 893550 Status: Offline Thanks Meter: 139 | Quote:
"ClockworkMod Touch Recovery Installation: 0. Go to Download Mode By Pressing (Volume Down +Home +Power) And Connect Your Phone To PC 1. Launch Odin v3.07 2. Browse Recovery File as PDA 3. Hit Start and Wait 4. After Installation Go To CWM By Pressing (Volume Up +Home +Power) 5. Make Sure That In Odin the Auto Reboot And F.Reset Time Checkboxes Are Selected, Uncheck The Re-Partition And Other Option" cwm recovery https://docs.google.com/file/d/0B_SF...it?usp=sharing super su SuperSU Download fix recovery Fix-Recovery 1. Place the downloaded SuperSu.zip and Fix-Recovery.Zip files on your phone’s external SDcard (make sure that it’s not on internal). 2. Now boot your phone into the recovery mode. In order to do so, press and hold the Volume Up + Home Button + Power Keysimultaneously. Your phone should now boot into recovery mode. 3. Tap install zip from SDcard > choose zip from sd card and choose the file Fix-Recoery.Zip and let it flash the Fix-Recovery. 4. Tap install zip from SDcard once again, and then choose zip from sd card, this time you need to select SuperSu.zip file and wait for it to flash the SuperSu thanks if help | |
The Following User Says Thank You to hajukhan For This Useful Post: |
07-30-2014, 05:20 | #10 (permalink) |
Junior Member Join Date: Oct 2010 Location: madhy pradesh
Member: 1412237 Status: Offline Sonork: 100.1663820 Thanks Meter: 18 | my og samsung i9082 not root volocono box help me Connecting device... Device connection is successful. Root process may restart the device several times, keep your device and data lines connected correctly. Getting Root privileges, please wait... Device Model: GT-I9082 Android Release: 4.2.2 Device is restarting, please keep your device and data lines connected correctly. >>Forced to disconnect from the phone by other similar software, turn off them, and re-start root. |
