volcano box stop working i was using latest ver of volcano box 2.92......bt today after doing window it stop's............i hv tried with several drivers uninstall and install vol software ........three times i hv dne window bt always failed checked on 2 machine.........wat is the problem http://img537.imageshack.us/img537/7861/vHuUR4.png |
what error are you facing? post screenshot please |
box not found............... |
Check the usb cable. Also disconnect if any other box connect to the PC. Also check if volcano box on/off switch is not in switched on, if on, then off it and try to connect. Ur problem will be solved. Post result. Br Chandan |
Remove All Device and Than Connect Box , Uninstall Box Drivers and Install New Latest One !! BR, MUKESH RAJ |
i hv tried bt didn't work |
Contact me on Sonork / Skype !! BR, MUKESH RAJ |
if already installed driver box of volcano and pc connected in stable connection run the gui in VOLCANO v2.2.8 first see result or error come out... |
driver problem 10000 %soulation |
Hello, Please check RED button. it's should be Unpressed condition Br Faisal_Computer |
