04-23-2012, 07:56 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 1280 infineon tested in Dolphin Clip SmartGsm by User alex_030385 logs: Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** START INFINEON BUS CHECK ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v ****************************************************** INFINEON BUS CHECK DONE ****************************************************** MCU: V 06.20 01-12-10 RM-647 (c) Nokia IMEI: 355351045118559 Product Serial Number: 4B92FC9AI Product Code : 0593133 Module Code : 0204426 Basic Production Code: 059C7H2 PPM SW Version : V 06.20 01-12-10 RM-647 (c) Nokia MA ADSP Version : p V 06.20\n01-12-10\nRM-647\n(c) NMP\nma MCU SW Version : V 06.20 01-12-10 RM-647 (c) Nokia HW Version : 3001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:SERI:90 NT7542 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... MCU: V 06.20 01-12-10 RM-647 (c) Nokia IMEI: 355351045118559 Product Serial Number: 4B92FC9AI Product Code : 0593133 Module Code : 0204426 Basic Production Code: 059C7H2 PPM SW Version : V 06.20 01-12-10 RM-647 (c) Nokia MA ADSP Version : p V 06.20\n01-12-10\nRM-647\n(c) NMP\nma MCU SW Version : V 06.20 01-12-10 RM-647 (c) Nokia HW Version : 3001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:SERI:90 NT7542 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED ================================================ Phone Lock / Security Code ================================================ SECURITY_CODE : ÿ |
The Following 3 Users Say Thank You to alex_030385 For This Useful Post: |
04-23-2012, 08:18 | #2 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | thanks for sucessfully report .. ... also i see . smile on your face br., |
The Following 2 Users Say Thank You to Smart-gsm For This Useful Post: |
04-23-2012, 09:52 | #3 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | dolphin clip swimming in old and new phone... 6070 tested: Uploaded with ImageShack.us logs: Code: Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 21 lsbUPP_ID : 42 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0020 - ST DevId0 : 882E - Type not in database ExtId0 : 0000 RevId0 : 7121 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 56 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84F2EFFFBD3DCEC793731AF9F6 DecodedMSID: 843E4EBAE9001F2D3CAA000000 EncodedFAID: 109AD8043A5110F7984833F9 Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 03.22 20-07-06 RM-166 (c) Nokia. IMEI: 353664011965866 Model : Nokia 6070 Product Serial Number: DGP080067 Product Code : 0534425 Module Code : 0202972 Basic Production Code: 0531001 PPM SW Version : V 03.22 20-07-06 RM-166 (c) Nokia. Q MCU SW Version : V 03.22 20-07-06 RM-166 (c) Nokia. HW Version : 4051 UEM Version : 416 UPP Version : 8514 RFIC Version : 0205 DSP Version : P05w06.v35 LCD Version : SUEZ ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000000002 ASIC : 2 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 0540557430 PHONE_MODE : LOCAL |
The Following User Says Thank You to alex_030385 For This Useful Post: |
04-23-2012, 11:25 | #5 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 1680c tested in a dolphin clip... Uploaded with ImageShack.us logs: Code: Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 62 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0001 - SPANSION DevId0 : 317E - Type not in database ExtId0 : 0041 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 1A ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_amd.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84AC86029D7A0BB480C221E516 DecodedMSID: 84CDF1BAEF0006FECCAA00024D EncodedFAID: D6116B8FB188DDCE67DF13D3 Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 05.61 18-04-08 RM-394 (c) Nokia IMEI: 355727022696214 Model : Nokia 1680c-2 Product Serial Number: IFM980510 Product Code : 0561441 Module Code : 0203777 Basic Production Code: 0556746 Long Production SN : 0 PPM SW Version : V 05.61 18-04-08 RM-394 (c) Nokia IC HW Version : 3000 UEM Version : 1328 UPP Version : 12642 RFIC Version : 0500 DSP Version : P06w45.v48 LCD Version : SUEZ Content Pack Version : Content: ic V 05.61 18-04-08 RM-394 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000001000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 91188 MASTER_CODE : 7015333116 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D1012601022C00 DCC Ver: 001003 Status : OK |
04-23-2012, 11:29 | #6 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 6101 tested in a dolphin clip... Uploaded with ImageShack.us logs: Code: Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 21 lsbUPP_ID : 42 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0020 - ST DevId0 : 882E - Type not in database ExtId0 : 0000 RevId0 : 7121 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 56 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 84FE5FE01A2F4E933FA097B0A9 DecodedMSID: 843E4EBAE9000260F7AA000000 EncodedFAID: 938744005490614193177DE7 Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 04.90 10-05-06 RM-161 (c) Nokia. IMEI: 359373000923258 Model : Nokia 6103 Product Serial Number: COE003108 Product Code : 0518684 Module Code : 0202199 Basic Production Code: 0520146 PPM SW Version : V 04.90 10-05-06 RM-161 (c) Nokia. X MCU SW Version : V 04.90 10-05-06 RM-161 (c) Nokia. HW Version : 5576 UEM Version : 400 UPP Version : 8514 RFIC Version : 0205 DSP Version : P05w06.v35 LCD Version : SUEZ ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000000002 ASIC : 2 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 123456 MASTER_CODE : 7656214463 PHONE_MODE : LOCAL |
04-23-2012, 11:36 | #7 (permalink) |
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | perfect friend ... hope i will see more feedback from you br., smartgsm |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
04-24-2012, 03:24 | #8 (permalink) |
No Life Poster Join Date: Sep 2010 Location: philippines
Member: 1388679 Status: Offline Sonork: 1597516:GsmSolution Thanks Meter: 2,757 | fell the power of dolphin clip how stable is the connection....thanks for the test report br, GsmSolution.Biz |
The Following User Says Thank You to GsmSolution. For This Useful Post: |
04-24-2012, 04:50 | #9 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 6500c tested in dolphin clip... Uploaded with ImageShack.us logs: Code: Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1B400210 ID DWORD 1 : C8814650 ID DWORD 2 : 600EB01B ID DWORD 3 : B1E48420 ID DWORD 4 : 769CD07F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum D2 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= FlashInfo.RestartMode : 2 ================================================ Basic Phone Information ================================================ MCU Version: V 12.35 11-11-09 RM-240 (c) Nokia IMEI Plain : 353076020298579 IMEI Spare : A353076020298570 IMEI SV : 33530760202985781F Phone Model: Nokia 6500s-1 Category : Connect Phone Phone Type : RM-240 ================================================ Extended Phone Information ================================================ Product Serial Number: CWA861629 Product Code : 0555552 Module Code : 0203327 Basic Production Code: 0543753 Long Production SN : 0 PPM SW Version : V 12.35 11-11-09 RM-240 (c) Nokia A MCU SW Version : V 12.35 11-11-09 RM-240 (c) Nokia HW Version : 1003 RFIC Version : 17141715 DSP Version : ICPR71_09w06 LCD Version : SHARP Content Pack Version : Content: a_3_se_silver_v2 V 12.35 11-11-09 RM-240 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:1F:5C:77:79:61 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA V ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000002 PROVIDER KEY : 2342000000000000 NETWORK NAME : Hutchison 3G UK Ltd;UK [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open Block [2] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... *** WARNING ** WARNING ** WARNING ** WARNING *** DO NOT USE FIRMWARE VERSION 5x.xx if your Phone does not have SL3 Type Simlocks and Security!!! Examples of SL3 Firmwares: v56.26, v57.23, v57.20, v58.58, v59.42, v59.60 *** WARNING ** WARNING ** WARNING ** WARNING *** |
The Following 2 Users Say Thank You to alex_030385 For This Useful Post: |
04-24-2012, 05:06 | #10 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | E63 sl3 decrypt and unlock in a dolphin clip... Uploaded with ImageShack.us logs: Code: ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w22 29-05-09 RM-437 (c) Nokia IMEI Plain : 35030385 IMEI Spare : A3030358650 IMEI SV : 3303038516505F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 PM 120 Found... PM 308 Found... Simlock Data Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w22 29-05-09 RM-437 (c) Nokia IMEI Plain : 30303851650 IMEI Spare : A303038450 IMEI SV : 3303038516505F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 Reading PM from 0 - 400 Found PM Section: 1 , 25 Items Found PM Section: 2 , 1 Item Found PM Section: 4 , 7 Items Found PM Section: 8 , 9 Items Found PM Section: 11 , 128 Items Found PM Section: 12 , 1 Item Found PM Section: 26 , 2 Items Found PM Section: 29 , 1 Item Found PM Section: 31 , 1 Item Found PM Section: 44 , 1 Item Found PM Section: 50 , 3 Items Found PM Section: 54 , 2 Items Found PM Section: 88 , 1 Item Found PM Section: 96 , 1 Item Found PM Section: 107 , 6 Items Found PM Section: 117 , 3 Items Found PM Section: 120 , 4 Items Found PM Section: 193 , 4 Items Found PM Section: 208 , 1 Item Found PM Section: 217 , 1 Item Found PM Section: 239 , 6 Items Found PM Section: 308 , 8 Items Found PM Section: 309 , 9 Items Found PM Section: 313 , 1 Item Found PM Section: 322 , 1 Item Found PM Section: 334 , 1 Item Found PM Section: 341 , 3 Items Found PM Section: 354 , 1 Item Found PM Section: 356 , 2 Items PM File SAVED TO : C:\AdvanceBox Turbo Flasher\Nokia\Backup Time Taken to Read PM : 00:00:43 ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w22 29-05-09 RM-437 (c) Nokia IMEI Plain : 3503038521650 IMEI Spare : A30303845021650 IMEI SV : 330303856505F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 ================================================ Extended Phone Information ================================================ Product Serial Number: MSC691321 Product Code : 0585258 Basic Production Code: 0561985 Long Production SN : 0 MCU SW Version : V ICPR71_09w22 29-05-09 RM-437 (c) Nokia HW Version : 0904 RFIC Version : 17141716 DSP Version : sofie-ICPR71_09w20 Content : )200.21.012 18-06-2009 RM-437 (c)Nokia AHNE Version : 11 APE SW Core Version : 200.21.012 Variant Version : 200.21.012200.21.012_v267.03 APE Test Version : RM437ENO874571920.014 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : D8:75:33:8D:8C:C3 Bluetooth ID : D8:75:33:8D:75:53 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2342000000000000 NETWORK NAME : Hutchison 3G UK Ltd;UK [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close Block [3] 1:Close Block [4] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================ Decrypting PM 120... PM 120 HASHES Extracted Successfully 2664B58672ACCF36EFFAD5FD502E303F6A6B81C9 7A6C5962B50BA537C18EB6A0A9BA4E19CDC53E6B DE7AEFCF38F0FD67B85635B12F7A69E605FE4432 AC6162251BD2C75E3F3840D304063DFC7FD7BCA6 A93D7747EDD97412D04C1A941B51213ED4C6D5B3 A255CB9040667722CBE0E2245FE0B83B243305EB 8B3E617BF7A5410427501C9B480241B1E4DD26D9 9FE6EF2C09D63450D491837C50739F6AC56C5E1F Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\030385\303038521650.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35203038550\350303851650.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352030385650\35030385650.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\3520303861650\352030385650.sha Command Line for ighashgpu: Saved as MS Batch File: 352030385650_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 3520303851650_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 35030385021650_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 3520303851650_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 352030385650_NVIDIA_cudaHashcat_32-bit.bat Process Done! 11:58:33 : SW: V 07.16 13-01-12 RM-639 (c) Nokia 11:58:33 : IMEI: 357387046402616 11:58:33 : CONFIG KEY : 0000000000000000 11:58:33 : PROVIDER KEY : 2440700000000000 11:58:33 : NETWORK NAME : Nokia Default;Finland 11:58:33 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 11:58:33 : SIMLOCK TABLE : 11:58:33 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:33 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:33 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:33 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:34 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:34 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:34 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 11:58:34 : SIMLOCK STATE : Not Locked 11:58:34 : 11:58:34 : SIMLOCK_TEST : PASSED 11:58:34 : SECURITY_TEST : PASSED 11:58:34 : SUPER_DONGLE_TEST : PASSED 11:58:34 : SECURITY_CODE : 312312 11:58:34 : 11:58:34 : ================================================ 11:58:34 : SL3 Phone detected 11:58:34 : ================================================ 11:58:34 : 11:58:34 : * Firmware Version Downgrade will KILL PHONE !!! 11:58:34 : * Manual Full Erase WILL KILL PHONE!!! 11:58:34 : * Simlocks are in PM 120 Only... 11:58:34 : * PM 308 is Write Protected... |
04-24-2012, 05:22 | #11 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 2700 hang tested in a dolphin clip... Uploaded with ImageShack.us logs: Code: Version from phone: 07.80 Version from file: 09.97 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0857702 Using device: HTI, FW ver: 00.50, SN: 00005D3E Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Reading RPL backup ... Reading Phone IDs ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 143002015EAB0256937E61D3DB4F5C062C247586 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F PUBLIC ID: 143002015EAB0256937E61D3DB4F5C062C247586 PRIVATE ID: 125A20D9A03C2A1DA0B7A4813979DE6C4FEA37B8 E-FUSE: C5D5525E SEC ROM CRC: DFAAF68F productData saved. Restarting phone ... Reading Secure Storage ... Reading Important data ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 143002015EAB0256937E61D3DB4F5C062C247586 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Flash Imei: 35484904396742 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35484904396742_BACK.rpl" CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 143002015EAB0256937E61D3DB4F5C062C247586 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F TransmissionMode: DDR&TX2 Processing MCU file: rm561__09.97.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 19.454 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 16.766 s Processing PPM file: rm561__09.97.ppm_ad1 [BB5,BB5 ALGORITHM] size: 5.50 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 23.922 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 29.234 s Processing CNT file: rm561__09.97_ISM_006.image_ad1_black_ctv_de_v2 [BB5,BB5 ALGORITHM] page size: 128 K size: 11.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 20.500 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 57.047 s Processing MMC file: rm561__09.97_sd_empty.fpsimage [BB5,BB5 ALGORITHM] version: 0.0.0 size: 273.36 KB Supported Ids: 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Erase skipped. Flash programming ... Error while programming [00] at 0x00020000, Result: 0000 Warning: programming MMC failed, please check if MicroSD exist ! Programming completed in 20.922 s ERROR: Packet Error(0xAA), code 0xCB000003 Total time for flashing process(boot+erase+write) was 7 min 19.016 s Phone type: RM-561 (Nokia 2700 classic) SW version: V 09.97 18-06-10 RM-561 (c) Nokia Imei plain: 35484904396742-3 Product code: 0589277 Battery voltage: 4148 mV, current: 12 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF0A021001, ver: 002.007 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354849043967423 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-24-2012, 05:38 | #12 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 6170 old tested in a dolphin clip... Uploaded with ImageShack.us logs: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0857702 Using device: HTI, FW ver: 00.50, SN: 00005D3E Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 0000 0001 [unused/removed] FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 00421FFD:3B8ADA60 ASIC type: 6 UEM Imei: 35501600528720 Flash Imei: 35501600528720 MasterCode: 2247734516 RPL saved to "C:\mobileEx\3.5\data\backup\35501600528720_BACK.rpl" Phone type: RM-47 (Nokia 6170) SW version: V 03.211 11-11-04 RM-47 6170 (c) Nokia. Imei plain: 35501600528720-3 Imei OTP: 35501600528720 Product code: 0521387 Cellular system: GSM ASIC ID: 0x1052, type: 6 Ppm Id: K Language Pack: English,German,Russian,Bulgarian,Romanian,Ukrainian Master code: 2247734516 Camera config: S Security code: 12345 "C:\Program Files\Nokia\Phoenix\Products\RM-47" folder created. Imei net: 35501600528720 Version: SIMLOCK SERVER VERSION 50 - Extended TDS-6 box range Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-24-2012, 05:46 | #13 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 7270 old tested in a dolphin clip... Uploaded with ImageShack.us logs: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0857702 Using device: HTI, FW ver: 00.50, SN: 00005D3E Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 00860BAD:3B8ADA60 ASIC type: 6 UEM Imei: 35501500192729 Flash Imei: 35501500192729 MasterCode: 5473126143 RPL saved to "C:\mobileEx\3.5\data\backup\35501500192729_BACK.rpl" Phone type: RM-8 (Nokia 7270) SW version: V 03.22 25-11-04 RM-8 7270 (c) Nokia. Imei plain: 35501500192729-1 Imei OTP: 35501500192729 Product code: 0521365 Cellular system: GSM ASIC ID: 0x1052, type: 6 Ppm Id: H Language Pack: English,Greek,French,German Master code: 5473126143 Camera config: S Security code: 021584 "C:\Program Files\Nokia\Phoenix\Products\RM-8" folder created. Imei net: 35501500192729 Version: SIMLOCK SERVER VERSION 50 - Extended TDS-6 box range Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-24-2012, 13:56 | #14 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | 302 new decrypt in atf and unlock with dolphin clip... Uploaded with ImageShack.us logs: Code: Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 11 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : AA3C0000 ID DWORD 1 : FFFB3C40 ID DWORD 2 : 5922DB19 ID DWORD 3 : 8C7C4557 ID DWORD 4 : 92E726F8 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B Checksum 6F SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Boot File - Version 011.048.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0241 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 07 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0241 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm File - Version 011.048.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Scanning Simlock Applet Type... OK ================================================= PA_SIMLOC30 Applet detected Use "Scan Phone" Button to Check if this Phone uses a 15-digit NCK or a 20-digit NCK... ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FlashInfo.RestartMode : 2 ================================================ Basic Phone Information ================================================ MCU Version: V 14.26 23-01-12 RM-813 (c) Nokia IMEI Plain : 358629043589666 IMEI Spare : A358629043589660 IMEI SV : 33586290435896604F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 80DD9A5AH Product Code : 059N2G7 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.26 23-01-12 RM-813 (c) Nokia OC3 BT MCM Version : 4217-v924 MCU SW Version : V 14.26 23-01-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.b.1 DSP Version : 104_MP5.2_14.26 LCD Version : TPO FWID Version : kV 14.26 23-01-12 RM-813 (c) Nokia V 14.26 23-01-12 RM-813 (c) Nokia OC3 059N2G7 004 HW Driver Version : - Content Pack Version : Content: c4_059K7T5 V 14.26 23-01-12 RM-813 (c) Nokia AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 50:2D:1D:62:6F:0E Bluetooth ID : 50:2D:1D:61:36:8E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2280300000000000 NETWORK NAME : Orange Communications SA;Switzerland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... ================================================ Basic Phone Information ================================================ MCU Version: V 14.26 23-01-12 RM-813 (c) Nokia IMEI Plain : 358629043589666 IMEI Spare : A358629043589660 IMEI SV : 33586290435896604F Phone Model: Nokia 302 Category : Phone Phone Type : RM-813 ================================================ Extended Phone Information ================================================ Product Serial Number: 80DD9A5AH Product Code : 059N2G7 Module Code : 0205095 Basic Production Code: 059J0F3 Long Production SN : 0 PPM SW Version : V 14.26 23-01-12 RM-813 (c) Nokia OC3 BT MCM Version : 4217-v924 MCU SW Version : V 14.26 23-01-12 RM-813 (c) Nokia HW Version : 1500 RFIC Version : |Alli_4.b.1 DSP Version : 104_MP5.2_14.26 LCD Version : TPO FWID Version : kV 14.26 23-01-12 RM-813 (c) Nokia V 14.26 23-01-12 RM-813 (c) Nokia OC3 059N2G7 004 HW Driver Version : - Content Pack Version : Content: c4_059K7T5 V 14.26 23-01-12 RM-813 (c) Nokia AHNE Version : 21 RETU Version : 51 TAHVO Version : 00 Wireless LAN ID : 50:2D:1D:62:6F:0E Bluetooth ID : 50:2D:1D:61:36:8E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2280300000000000 NETWORK NAME : Orange Communications SA;Switzerland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================ Decrypting PM 120... PM 120 HASHES Extracted Successfully 5BCF3DEF7AEA33BAC872B02BCC5DF526759729BA B439DE06FA4C85C5BFE5588E7EF242835931F75D 36B6473E61CC8E1E599490093176436B4E25A2F8 4C072CDE0BE0C6D28712CEC27550A1DE6ACC39F0 BD3744C46D876D0697C0D107670CFB11B43E74D5 739822397654C1DA228E1903B64B13ED2498A21D 5EAA4FDA45682D05089357F707A53243471E44A3 487DD537502EFED558918A6730DF629CC98386B6 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\3503038589666\35030385679889666.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35040404869666\30303049848689666.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\3503034858669666\350303858586666.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\350303859666\3503038589666.sha Command Line for ighashgpu: Saved as MS Batch File: 35030385589666_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 350303859666_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 350303859666_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 3503038589666_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 35030385666_NVIDIA_cudaHashcat_32-bit.bat Process Done! ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2280300000000000 NETWORK NAME : Orange Communications SA;Switzerland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2280300000000000 NETWORK NAME : Orange Communications SA;Switzerland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 004006 Status : OK |
04-25-2012, 08:07 | #15 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | x6-00 show decrypt and unlock in atf with dolphin clip... Uploaded with ImageShack.us logs: Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020802 Library Version : 00030200 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.12 Software Version : v8.63 AdvanceBox SN : D18alex_030358A31A706B Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia IMEI Plain : 35alex_030356800 IMEI Spare : A3alex_0303556800 IMEI SV : 33alex_030358061F Phone Model: Nokia X6-00 Category : Classic Phone Phone Type : RM-559 ================================================ Extended Phone Information ================================================ Product Serial Number: CSG099952 Product Code : 059B771 Basic Production Code: 0589312 Long Production SN : 0 MCU SW Version : V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia HW Version : 1123 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR72_09w53 Content Pack Version : 10.5.089_001_U356 r RM559_002_001_M001 AHNE Version : 11 APE SW Core Version : V 10.5.089 Variant Version : V 10.5.089V 10.5.089 10.5.089.356.02 APE Test Version : rm559_ENO_A_09wk28v0.470 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 6C:9B:02:62:21:4E Bluetooth ID : 6C:9B:02:61:D3:2E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 NETWORK NAME : T-Mobile ;Austria [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia IMEI Plain : 35alex_030356800 IMEI Spare : A3alex_03035800 IMEI SV : 335alex_030351F Phone Model: Nokia X6-00 Category : Classic Phone Phone Type : RM-559 ================================================ Extended Phone Information ================================================ Product Serial Number: CSG099952 Product Code : 059B771 Basic Production Code: 0589312 Long Production SN : 0 MCU SW Version : V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia HW Version : 1123 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR72_09w53 Content Pack Version : 10.5.089_001_U356 r RM559_002_001_M001 AHNE Version : 11 APE SW Core Version : V 10.5.089 Variant Version : V 10.5.089V 10.5.089 10.5.089.356.02 APE Test Version : rm559_ENO_A_09wk28v0.470 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 6C:9B:02:62:21:4E Bluetooth ID : 6C:9B:02:61:D3:2E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 NETWORK NAME : T-Mobile ;Austria [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL ================================================ Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================ Decrypting PM 120... PM 120 HASHES Extracted Successfully E63DD4592051E3014B72406001AD630F7BD1E4D5 66E05A6C9A394325FBA2FE1CE3003D0D88F9100F 1259EF18BD7DC75277D64A467B6DEE108D8134C6 2BF001850FFC9D019136B182D415B1765A116740 AF3C8473EA29B6773D69AD65884A6F8D246AE8CA D04E1F3F0B464347485BA8E859EA644163CA2E79 53B2ACBFD1DC811424E326B0BBC219D89CB06652 81284C9CBA7B374E4AF8778C1A7C5DCE34198AB2 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35alex_0303500\35alex_030356800.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35alex_03035800\353alex_03035800.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35alex_03035800\35alex_030356800.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\35alex_03035800\35alex_03035800.sha Command Line for ighashgpu: Saved as MS Batch File: 35alex_03035800_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 35alex_030356800_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 35alex_03035800_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 35alex_030356800_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 35alex_0303556800_NVIDIA_cudaHashcat_32-bit.bat Process Done! ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia IMEI Plain : 35alex_030356800 IMEI Spare : A3alex_030356800 IMEI SV : 33alex_030358061F Phone Model: Nokia X6-00 Category : Classic Phone Phone Type : RM-559 ================================================ Extended Phone Information ================================================ Product Serial Number: CSG099952 Product Code : 059B771 Basic Production Code: 0589312 Long Production SN : 0 MCU SW Version : V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia HW Version : 1123 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR72_09w53 Content Pack Version : 10.5.089_001_U356 r RM559_002_001_M001 AHNE Version : 11 APE SW Core Version : V 10.5.089 Variant Version : V 10.5.089V 10.5.089 10.5.089.356.02 APE Test Version : rm559_ENO_A_09wk28v0.470 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 6C:9B:02:62:21:4E Bluetooth ID : 6C:9B:02:61:D3:2E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 NETWORK NAME : T-Mobile ;Austria [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL Sending SP code: #pw+444610439216705+7# Sending FBUS Command FBUS Command Sent OK: code accepted ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia IMEI Plain : 35alex_030356800 IMEI Spare : A3alex_03035800 IMEI SV : 335alex_030358061F Phone Model: Nokia X6-00 Category : Classic Phone Phone Type : RM-559 ================================================ Extended Phone Information ================================================ Product Serial Number: CSG099952 Product Code : 059B771 Basic Production Code: 0589312 Long Production SN : 0 MCU SW Version : V ICPR72_09w53.1 03-03-10 RM-559 (c) Nokia HW Version : 1123 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR72_09w53 Content Pack Version : 10.5.089_001_U356 r RM559_002_001_M001 AHNE Version : 11 APE SW Core Version : V 10.5.089 Variant Version : V 10.5.089V 10.5.089 10.5.089.356.02 APE Test Version : rm559_ENO_A_09wk28v0.470 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 6C:9B:02:62:21:4E Bluetooth ID : 6C:9B:02:61:D3:2E CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2320300000000000 NETWORK NAME : T-Mobile ;Austria [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
