03-06-2014, 20:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | unlock st21i done Checking connection...OK Connecting server using ...OK License name: 4SE Server Credits Time left: 363 days Credits available: ------------------ Selected model: Xperia™ J (ST26) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Checking ADB drivers status...FAILED Install ADB drivers before starting Unlock operation Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB1 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227A Model:ST26i IMEI:35184706 --------AID:0002 Color:RED DEVICE_ID: A7C8815AE3DF2AFC998EC7839E8389BAAFE916B7 EROM: 1264-2299 R10--030 Uploading logic MSM7227A: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 3728 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.31) Waiting for YT910LDM5E...OK Disabling security...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [3367sec] |
The Following User Says Thank You to abbasgh For This Useful Post: |
03-09-2014, 09:47 | #2 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | http://forum.gsmhosting.com/vbb/f732...ongle-1455693/ - this is the ideal thread to post your successful logs |
The Following User Says Thank You to Hams For This Useful Post: |
