06-07-2012, 20:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | SuccessFully UnlockXperia™ neo V (MT11)[Solved] Selected model: Xperia™ neo V (MT11) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader...OK Connected to USB3 Sending LoaderTEST...OK Chip:QC8255 Model:MT11i IMEI:35851704-8184**-* AID:0001 Color:BROWN DEVICE_ID: 6C8C76C812CC4F7139F2E3A803F093486251F5D0 Uploading logic QC8255: Detecting flash type...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [656sec] |
The Following 6 Users Say Thank You to bux_harun For This Useful Post: |
06-09-2012, 18:38 | #4 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1271770 Status: Offline Thanks Meter: 28 | 1. I connect the POINT TestPoint to a GND by a simple metal cable. 2. After connect de USB cable to PC. 3. In Device Manager create a nuevo PORT COM named: %QcomDevice90080% (COM431) But nothing to do Please, What can I do ??? 4SE - tool 1.8.5 (S/N:132XXXXXXX) Selected model: Xperia™ neo V (MT11) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)Remove battery. Link the TestPoint to GND and then plug USB cable |
06-10-2012, 14:17 | #6 (permalink) | |
Member: 1271770 Status: Offline Thanks Meter: 28 | Quote:
06-10-2012, 18:01 | #8 (permalink) |
Member: 1638915 Status: Offline Thanks Meter: 432 | How To Unlock 1) Select modal on 4se 2) Click START botun 2) Canect Usb Cable On pc 3) Canect Test point 4) After Canect USB Cable Phone 5) After PC take Driver If Pc Not Take Driver Select This driver Manual Best Of luck |
The Following User Says Thank You to bux_harun For This Useful Post: |
06-11-2012, 15:03 | #10 (permalink) |
Member: 1271770 Status: Offline Thanks Meter: 28 | Sony Ericsson MT11i Unlock STEP 1. Install the drivers that are in the installation folder of the 4SE (Windows XP Start Button - All Programs - 4SE) a) Install Drivers ADB b) Install Drivers USBFlash 2. Remove the battery 3. Connect with TESTPOINT point GND (for example where you put the MicroSD) 4. Start the Unlock 5. Connect the USB cable 6. It detects the phone and displays a sign indicating TESTPOINT remove and then click Button OK 7. Continuing the process and unlocked phone in 77 seconds |
The Following User Says Thank You to richardex78 For This Useful Post: |
06-15-2012, 12:05 | #11 (permalink) | |
Member: 1638915 Status: Offline Thanks Meter: 432 | thaks bro Quote:
Thanks Bro good job good intodecsan | |
Help solve an argument !! | zeaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-10-2001 13:11 |
how do you solve no signal - 5110? | philipal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 03:27 |
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. | jsp_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-14-2001 19:52 |
3210 atmel solved | bone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-18-2001 12:11 |
PROBLEM SOLVED (Flasher error tx=0 tx=1...) | lanzar | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-30-2000 15:47 |
