11-05-2014, 10:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 444378 Status: Offline Thanks Meter: 3 | Neo V unlock problem 4SE - tool 2.0.4 (S/N:000000000549 V2.0) Selected model: Xperia™ neo V (MT11) Selected operation: Unlock Selected interface: USB (BOOTROM) Checking USB driver status...OK (SOMC Flash Device v3.1.0.0 | 3-24-2014) Remove battery. Link the TestPoint to GND and then plug USB cable Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Sending Preloader... Error connecting device: Preloader check timed out Note: Devices manufactured after 12W10 have no support for TestPoint operations STOPPED [34sec] |
11-06-2014, 16:09 | #2 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | Devices manufactured after 12W10 have no support for TestPoint operations STOPPED [34sec] check sticker backside it is manufactured after 12w10 so cant unlock with cable..u have to use Imei to unlock |
The Following User Says Thank You to abbasgh For This Useful Post: |
11-07-2014, 17:29 | #3 (permalink) |
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | 4SE - tool 2.0.4 (S/N:00000000xxxA V2.0) Selected model: Xperia™ neo V (MT11) Selected operation: Desbloqueo Selected interface: USB (BOOTROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery. Link the TestPoint to GND and then plug USB cable Conexión establecida al puerto USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal... Connecting DLOAD...OK (PBL_DownloaderVER1.0) Enviando Preloader...OK Conexión establecida al puerto USB3 Enviando LoaderTEST...OK Chip:MSM8x55 Model:MT11i IMEI:35851704-09xxxx-x AID:0001 Color:BROWN DEVICE_ID: D0E78E3A893C7F21C11B738C036D0964CA7D82FF Enviando logic MSM8x55: Detectando tipo de flash...OK ID: 2CB3 (Micron) Chip: Micron 8192 Mbit NAND (large page) x16 Logical address: 0x00000000 Size: 1056 Mb Logical block size: 0x20000 Logical blocks count: 0x2000 OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Prcessing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Writing S1boot image...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [27 seg] 11w39 and unlocked within in seconds Enjoy |
