Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > 4SE
Old 10-13-2014, 22:13   #1 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 432
Arrow xperia e unlock Error C1505
4SE - tool 2.0.4 (S/N:132F009***** V2.0)
Selected model: Xperia™ E (C1504)
Selected operation: Unlock
Selected interface: USB (EROM)
Checking USB driver status...FAILED (Device record missing)
Checking ADB drivers status...OK
Remove battery, wait a few seconds and insert it back
Plug USB cable holding "Volume Down" button
Connected to USB4
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...OK
Chip:MSM7227A Model:C1505 IMEI:35960805-690***-* AID:0002 Color:RED
DEVICE_ID: 208278C68BB67770C7343AE904C66E6CDBB61D01
EROM: 1264-2299 R10D030
Uploading logic MSM7227A:
Sending LoaderLIVE...OK
Detecting flash type...OK
OTP: LOCKED
Reading TA security data...OK
Opening TA...OK
Reading SIMLock data...OK
Resetting phone lock...OK
Original HwConf certificate detected
Processing SIMLock signature...
Failed to sign, code: 8815
STOPPED [5sec]
And Plese FIX BuG Not Found C1505 Modal Thanks 4se Team
Old 10-16-2014, 19:12   #2 (permalink)
Member: 1890459
Sonork: 100.1627340
Thanks Meter: 149
4SE - tool 2.0.4 (S/N:00000xxxxxxxxx V2.0)
Selected model: Xperia™ miro (ST23)
Selected operation: Desbloqueo
Checking USB driver status...ERROR (Device record missing)
Checking ADB drivers status...FAILED
Install ADB drivers before starting Unlock operation
Conexión establecida al puerto USB2
Identificando terminal...OK
Chip:MSM7225A Model:ST23i IMEI:35439005-060xxx-x AID:0002 Color:RED
DEVICE_ID: 6B7190B101531849B91A786C41C135D923F8654B
EROM: 1257-7605 R10D030
Enviando logic MSM7225A:
Enviando LoaderLIVE...OK
Detectando tipo de flash...OK
OTP: LOCKED
Opening TA...OK
Prcessing SIMLock signature...
Failed to sign, code: 43CE
Proceso abortado. Tiempo total [7 seg]
same error
Old 10-17-2014, 12:22   #3 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Both phones touched by other tool now need repair Trim Arena and this 4se not support just use other tools.
I personaly unlock few C1505 with 4se like C1504 without problem when phone is not played with other tool before.
Old 10-28-2014, 19:27   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
For me all work ok without problem.
4SE - tool 2.0.4 (S/N:000000000xxx V2.0)
Wybrany model: Xperia™ E (C1504)
Wybrana operacja: Odblokowanie
Wybrany interfejs: USB (EROM)
Sprawdzanie sterowników USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011)
Sprawdzenie statusu sterowników ADB...FAILED
Zainstaluj sterowniki ADB przed rozpoczęciem odblokowania
Wyciągnij baterię, odczekaj kilka sekund i włóż ponownie
Podłącz kabel USB trzymając przycisk "Głośność -"
Podłączony przez USB1
Możesz teraz puścić przyciski. Nie odłączaj telefonu.
Identyfikacja telefonu...OK
Chip:MSM7227A Model:C1505 IMEI:35742105-970383-2 AID:0002 Kolor:RED
DEVICE_ID: CD91D5AB83BDD88B6D52BBA9F543D4B05A11907B
Wgrywanie MSM7227A:
Wysyłanie LoaderLIVE...OK
Wykrywanie typu flasha...OK
Rozmiar: 3728 Mb
OTP: LOCKED
Odczyt obszaru zabezpieczeń TA...OK
Otwieranie TA...OK
Odczyt danych SIMLockOK
Resetowanie blokady telefonu...OK
Oryginalny certyfikat HwConf rozpoznany
Przetwarzanie danych SIMLockOK
Otwieranie TA...OK
Zapis danych SIMLock...OK
Odłącz kabel USB, włącz telefon i podłącz po uruchomieniu
W menu > Ustawienia >Aplikacje > Dla programistów włącz Debugowanie USB,
upewnij się, że masz zainstalowane sterowniki ADB. Podłącz kabel USB
Start serwera ADB...OK(v1.0.31)
Oczekiwanie na OK
Wyłączenie zabezpieczeń...OK
Wgrywanie obrazu S1boot....OK
Restart urządzenia...OK
Operacja zakończona pomyślnie. Możesz odłączyć telefon.
Zakończono [50sec]
Old 10-28-2014, 20:31   #5 (permalink)
Member: 2277168
brother can u please make a snopshot of driver installed in u device manager because i have 3 sets n have problem failed to sign in
Old 10-28-2014, 21:59   #6 (permalink)
Member: 2277168
which card do u have as i think this problem have with Feitian ..??? i dont know but as i ma seeing it has somting problem
Old 10-29-2014, 14:31   #7 (permalink)
Member: 2277168
ok finally solved with help of darkman..was a problem with card reader..
Page generated in 0.16130 seconds with 8 queries
