Qualcomm recovery cables E10http://unlock.se/images/REC/E10_REC.png E15http://unlock.se/images/REC/E15_REC.png U20http://unlock.se/images/REC/U20_REC.png X10http://unlock.se/images/REC/X10_REC.png Legendhttp://unlock.se/images/REC/REC_LEGEND.png Recovery cables are UART cable to qualcomm recovery interface. MSM7227 and QSD8250 requires recovery cable in order to perform recovery of dead phone. The interface could be also used for any other operation like flash or unlock. Firmware version doesn't metter when recovery interface used for unlock. QC8255 models dont require any special cable for recovery, Instead USB + Testpoint is used. |
and i think, we can use gpg setool(24kgold) as interface |
batter for 4se tool keep it up more hard working make market and make GUD Name--- |
Code: 4SE - tool 1.8.2 - Start with testpoint connected to ground ie toggle switch of the cable should be on "HW" mode(middle position of toggle swtich) - when it prompts to remove testpoint, change position of the toggle swtich to "red" mode on the cable(last position of toggle switch) - when software reconfirms about wd timer connected to Ground, press ok and this is the photo and video with rextor cable: http://forum.gsmhosting.com/vbb/8439157-post16.html |
Where to buy 4se resurection cable and tp cable for all new se models like ray, play, x10 mini, x8, x10 mini pro ...... |
http://forum.gsmhosting.com/vbb/f732...5/#post8305554 |
Like this ? not 4se res cable GSMSP | GPG Qualcomm Resurrection Cables Featuring Setool Box(X10i,U20i,E10i,E16i) |
Yes you can use them, interface setool box from GPG |
sir i don't know any thing about this key . but i already purchased . so can you update step by step user manual for 4se key? thanx in advance. |
Bro, if u have any fone in your hand for flashing & unlocking or facing any problem, u can call me any time @9815177706. Wbr s n hasan |
thanx hasan g 4 ur phone reply.any how whenever a phone came to me for flashing . i'll take help from u by team viewer. |
You can you post here your problem 4SE team and senior member always here for Help . :) |
how flash w200i? i am changing interface for comport z3x it not deducted.which cable to use? i am not understand plz help me. |
