03-04-2014, 13:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 591 | Unable to connect to server -Firewall deactivated -4SE app is included in antivirus exclusion. -i tried with antivirus disabled. -yesterday worked fine in the same computer with the same configuration.I have log posted of c1505 ulock done. Last edited by Punto-Móvil; 03-04-2014 at 13:45. |
03-04-2014, 14:16 | #2 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 591 | I uninstalled the antivirus completely and it worked perfect. I will install it again and test.Take a look to log HERE Best Regards. Punto-Móvil |
03-06-2014, 10:56 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Dubai, UAE
Member: 4929 Status: Offline Sonork: 100.37251 Thanks Meter: 238 | Shouldn't be any problems with any AV Also, the server is based in Ukraine and u know the current situation there, internet, electricity going on/off can be one of the reasons. Anyway, let darkmen see this post and reply. |
03-06-2014, 17:43 | #5 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | 4SE - tool 2.0.2 (S/N:00000000-...---- Checking connection... Unable to connect server. Please check Your connection STOPPED [64sec] problem with server...it does not seems to be problem with antivirus i check it with almost 3 computers |
03-29-2014, 06:31 | #10 (permalink) |
Junior Member Join Date: Jun 2008 Location: USA Brockton MA
Member: 785389 Status: Offline Thanks Meter: 6 | 4SE - client 2.0.2 Checking connection...OK Connecting server using credits2278...OK License name: 4SE Server Credits Time left: 362 days Credits available: (used: 0) Selected model: Xperia™ go (ST27) Selected operation: Unlock by signature Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Volume Down" button Connected to USB4 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:STE U8500 Model:ST27i IMEI:35511305-802429-2 AID:0001 Color:RED DEVICE_ID: 757CC41A582A9C72656A4F73DDCAD2E810A28E4B EROM: 1240-4128 R10E013 Uploading logic STE U8500: Sending LoaderLIVE...OK Detecting flash type...OK ID: SSD Size: 7576 Mb OTP: LOCKED Reading TA security data...OK Reading phone information...OK Reading SIMLock data...OK Processing SIMLock signature... Signature request failed with message: Signature server is currently offline (work hours: 02:30 - 09:30 GMT+0) STOPPED [9sec] |
