07-31-2014, 19:46 | #1 (permalink) |
Junior Member Join Date: May 2009
Member: 1041037 Status: Offline Thanks Meter: 1 | Blackberry Z10 LCD Connector Replaced Blackberry Z10 LCD phone only showed blank screen no image, but I made a jumper and it worked just fine...After 2days the jumper went out...tried to replace the jumper, no image at all only shows a blank background till it loads the Blackberry OS then it stays black...When I connect it to the computer I can see that the phone is working...but still no image... Any Schematics would appreciate! Thanks |
01-23-2015, 23:32 | #2 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2093407 Status: Offline Thanks Meter: 0 | i have kind of the same problem . phone starts with iluminated blak screen, boot's up fine tap 3 times power button, voice assistant can be heared) but with no image. please help Best regards |
01-24-2015, 08:46 | #3 (permalink) | ||
No Life Poster Join Date: Jan 2011 Location: united arab emirates (uae)
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | Quote:
check same verson of display.also check lc d connecter. | ||
01-26-2015, 23:38 | #4 (permalink) |
Member: 2093407 Status: Offline Thanks Meter: 0 | i have two z10 both STL 100-1 , one works as long as i keep a piece of paper between the logic board and the covering case, and the one with the display problem. i tried switching the display assembly but still no go. screen lights up for a few seconds phone boots up but no image. i looked at the lcd connector on the board and it's ok. is there a chip that needs reheating ? |
01-30-2015, 09:02 | #6 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
IN Z10 STL 100-1 where you had jumper those line please measure with multimeter you will get some of them is absent or reading is high.actually all lines must be similar.If absent or upset than that line is disconnect from cpu, by little bending you can see display.I had seen major case in STL 100-1,its board problem some where line getting disconnet or open link.No way to solve it. | |
