blackberry 9300 joystick problem dear sir or madam could you give me information about blackberry 9300joystick's if it's possible could you send me workout steps by pictures. our blackberry joystick from 9300 doesnt moves. thank you and kind regards. |
Your will need to replace your joystick you can buy them cheap 1 or 2 pound. First you will need too remove the 2 screws of the back of your phone. After this remove the casing faceplate and keypad. After remove the 2 screws from on top of the lcd screen and also the other 4 below on the motherboard. Now it should be loose u can pry your motherboard out Once its out you will see the connection from the trackpad to the motherboard take out old trackpad and replace with new. Yoi can now assembke phone back togethet. If you would like phone fixed i fix phones please message mr. |
1 Attachment(s) Quote:
try trick image below good luck |
9300 trackpad Quote:
Good Luck... |
