Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 05-19-2014, 19:34   #1 (permalink)
Member: 2189548
Unhappy blackberry q10 power button not working
The power button does not work. I can not lock the screen. But I can hold to reboot. I can not increase or decrease the volume outside the home screen, can not capture the screen by pressing two keys at the same time + - volume, but the volume changes when you turn on the music. I do not know how to fix it. Please help me. I love it.
Old 05-21-2014, 09:09   #2 (permalink)
Member: 25662
Thanks Meter: 190
do as per jpg bypass R3101 & remove D3104 (esd diod).
if sloved than enjoy otherwise POWER_KEY line goes direct to main power IC U2002
Refresh or Replace power IC.
Before refresh or replace IC once update it.
The Following 3 Users Say Thank You to Munir For This Useful Post:
Old 05-22-2014, 03:59   #3 (permalink)
Member: 2189548
Excellent. I will try. Thank you very much
Old 05-22-2014, 09:49   #4 (permalink)
Member: 2189548
I have tried several times but it did not work
Old 05-22-2014, 11:36   #5 (permalink)
Member: 25662
Thanks Meter: 190
1.Does your Q10 is water damage?
2.make sure your powerkey is ok.
3.Did you done as per jpg?
4.now don't connect connector & just takeout one jumper 10cm. long from C3118 as per jpg power on Q10 by touch this jumper to anywhhere ground.
5.beyond this direct main power IC.
The Following 2 Users Say Thank You to Munir For This Useful Post:
Old 05-22-2014, 17:32   #6 (permalink)
Member: 2189548
It does not stick water
The Powerkey works fine
I've done step by step in photos and try more.
I will try again.
Thank you so much.
Old 01-23-2015, 10:51   #7 (permalink)
Member: 1011778
Sonork: 0805
mine can power on but the key can not put it on sleep mode
Old 01-23-2015, 13:32   #8 (permalink)
Member: 1714774
does it power on with the power key
Old 01-24-2015, 06:23   #9 (permalink)
Member: 25662
Thanks Meter: 190
Test with jumper. may be switch get twice plus.Does it power off by long press?
Power key is necessary.Does it show charging?
Old 02-25-2015, 05:47   #10 (permalink)
Member: 2189548
It does not work. I sold it to buy a BB Z10. Thank you a lot
Old 03-01-2015, 06:27   #11 (permalink)
Member: 1609576
Thanks Meter: 14
Please sir,me too is having the same problem,but I don't know the meaning of that ''Bypass" that you said we should do,thanks sir.
Old 03-02-2015, 05:54   #12 (permalink)
Member: 25662
Thanks Meter: 190
remove that parts and make jumper direct point to point.
Old 08-02-2015, 07:53   #13 (permalink)
Member: 987487
Thanks Meter: 4
Remove u3306 and make jumper, it is magnetic sensor problem
The Following User Says Thank You to tjongi For This Useful Post:
Old 08-08-2015, 10:49   #14 (permalink)
Member: 2391835
Thanks Meter: 2
Try a battery pull out and wait few minute and insert again battery. now you can switch on
if your problem same so you can contact your nearly service center.i hope be solve your problem.
Old 11-17-2015, 11:23   #15 (permalink)
Member: 2488069
Thank you! I had the same problem as thangkoi. I removed U3306 as tjongi suggested and it solved the problem.
Page generated in 0.25871 seconds with 10 queries
