05-19-2014, 19:34 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2189548 Status: Offline Thanks Meter: 0 | blackberry q10 power button not working |
05-21-2014, 09:09 | #2 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 56
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
if sloved than enjoy otherwise POWER_KEY line goes direct to main power IC U2002 Refresh or Replace power IC. Before refresh or replace IC once update it. | |
The Following 3 Users Say Thank You to Munir For This Useful Post: |
05-22-2014, 11:36 | #5 (permalink) |
Member: 25662 Status: Offline Thanks Meter: 190 | 1.Does your Q10 is water damage? 2.make sure your powerkey is ok. 3.Did you done as per jpg? 4.now don't connect connector & just takeout one jumper 10cm. long from C3118 as per jpg power on Q10 by touch this jumper to anywhhere ground. 5.beyond this direct main power IC. |
The Following 2 Users Say Thank You to Munir For This Useful Post: |
01-24-2015, 06:23 | #9 (permalink) | |
Power key is necessary.Does it show charging? | |
08-02-2015, 07:53 | #13 (permalink) | |
Junior Member Join Date: Mar 2009
Member: 987487 Status: Offline Thanks Meter: 4 | Quote:
The Following User Says Thank You to tjongi For This Useful Post: |
08-08-2015, 10:49 | #14 (permalink) |
Banned Join Date: May 2015
Member: 2391835 Status: Offline Thanks Meter: 2 | Try a battery pull out and wait few minute and insert again battery. now you can switch on if your problem same so you can contact your nearly service center.i hope be solve your problem. |
