Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnBox Team Products > Mcnpro Light box
Old 06-06-2013, 05:11   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow ★★★★★Discussion here>> Mcnpro light Box version 1.3.0.3 ★★★★★
What's new for Mcnlight box version 1.3.0.3? New!! Hot!!
  • Improve MTK onekey Root function to be more stable
  • Fix MTK 657x Read & Write & Format Function bugs
  • SPD Android oneclick Root function added
  • SPD unlock function new method added
  • SPD Read IMEI New method added
  • SPD new flash ICs added
  • CoolSand New flash ICs added
  • CoolSand unlock function Improved
  • Android Read info function added
  • Android Reset /wipe function added
  • Android Reboot recovery function added
  • Some small reported bugs fixed
Upgrading from Previous Versions:
  • As usual, Version 1.3.0.3 request install version 1.3.0.1 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Best regards !
Mcnbox Team
The Following 3 Users Say Thank You to Mcnbox For This Useful Post:
Old 06-06-2013, 07:18   #2 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
realy hot update more hot updates coming soon ......... stay tuned .... !
Mcnlight_Box_version_1.3.0.3.rar_links
Old 06-06-2013, 11:38   #3 (permalink)
Member: 403149
****ing link and please repair link not working....
Old 06-07-2013, 03:29   #4 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
@All
New version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Best regards !
Mcnbox Team
Old 06-07-2013, 10:07   #5 (permalink)
Member: 739620
Thanks Meter: 18
The Following User Says Thank You to priatna For This Useful Post:
Old 06-07-2013, 11:26   #6 (permalink)
Member: 739620
Thanks Meter: 18
done downloading, must be outside instaler.
doing unlock coolsand
17:18:18 Phone detected, Wait...
17:18:21 Done.
17:18:21 CPU Type Coolsand (88063000)
17:18:21 Flash Type NOR
17:18:21 Flash ID 00C80040(00160000)
17:18:21 Flash Model GD25Q32
17:18:21 Flash Size 0x400000(4.0M)
17:18:21 Starting,Wait...
17:18:48 Unlock code *#06#
17:18:48 Unlock code *#12590#
17:18:48 Unlock code *#12591#
17:18:48 IMEI1 :1208484975451255
false password get . phone still locked
Old 06-07-2013, 19:04   #7 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
some phone lock need to full type this code
*#06#
*#12590#
*#12591#
Old 06-08-2013, 04:22   #8 (permalink)
Member: 739620
Thanks Meter: 18
*#06#
*#12590#
*#12591#
how can i type "*" phone just wanted to insert number only . how to ?
Old 06-08-2013, 05:33   #9 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
can read full flash then upload here well check
Old 06-08-2013, 05:40   #10 (permalink)
Member: 739620
Thanks Meter: 18
here nv from telego v600 cpu coolsand
https://docs.google.com/file/d/0B8y7...it?usp=sharing
mybe needed for investigation
Old 06-08-2013, 05:41   #11 (permalink)
Member: 844866
Thanks Meter: 22
Unlock Coolsand
Btw What u mean "Unlock" ?? And Wheres The Unlock Button...Youre log Is The Infos Only I guess
Old 06-08-2013, 06:15   #12 (permalink)
Member: 739620
Thanks Meter: 18
in unlock just two opyion there :
unlock code and analysis code , any other option in coolsand tab ?
here some full flash. but look like not full, the other part is on nv will not boot if only flashing by this one
Old 06-08-2013, 07:39   #13 (permalink)
Member: 844866
Thanks Meter: 22
Better Coolsand
We Need Coolsand Better Procees For User Code Read...If The Flashing Procees Cant For Now,,,,
The Following User Says Thank You to zacxrhay For This Useful Post:
Old 06-08-2013, 07:56   #14 (permalink)
Member: 739620
Thanks Meter: 18
problem solved. phone died. cannot write nv. after write and format many times
13:51:11 CPU Type Coolsand (88063000)
13:51:11 Flash Type NOR
13:51:11 Flash ID 00C80040(00160000)
13:51:11 Flash Model GD25Q32
13:51:11 Flash Size 0x400000(4.0M)
13:51:11 Initialize boot,Wait...
13:51:12 Boot Done.
13:51:12 Writing,Wait...
13:51:24 Write Error. ID:1557(61000)
Old 06-08-2013, 08:14   #15 (permalink)
Member: 844866
Thanks Meter: 22
Not Solved Yet
Problem Solved After You Buy 1 Brand New Phone to Replace..for Customer
Page generated in 0.21261 seconds with 8 queries
