10-25-2013, 17:59 | #1 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1400288 Status: Offline Thanks Meter: 21 | itel it1351 pettarn lock hang on itel logo ,can i backup its flash file? cos customers his very halas me software tell me [Flash File can not use for Flash] I NEED HELP MCN TEAM LOG IS HERE 10:13:12 Box Connected! 10:13:28 Scanning USB Serial port... 10:13:37 SU2Serial Port: COM27 10:13:37 Phone detected, Wait... 10:13:37 Done. 10:13:37 Info:SPRD3 10:13:37 Initialize boot9... 10:13:38 CPU Type 8810/6820 10:13:38 Flash Type NAND 10:13:38 Flash ID 00AD00BC 10:13:38 Flash Model HYNIX H8BCS0UN0MCR 10:13:38 Flash Size 0x20000000(512.0M) 10:13:38 Reading,Wait... 11:00:51 Read Done. 11:01:32 File saved:8810_6820_HYNIX H8BCS0UN0MCR.bin 11:01:32 Flash File can not use for Flash. |
01-18-2014, 20:28 | #3 (permalink) |
Member: 1400288 Status: Offline Thanks Meter: 21 | itel it1350 pattern lock DONE 20:05:33 Box Connected! 20:05:37 Searching USB to Serial Port... 20:06:07 Searching USB to Serial Port... 20:06:33 User Abort 20:06:33 USB port have not detect out 20:06:45 Scanning USB Serial port... 20:07:15 count:=0_ 20:07:15 USB Serial port Error. 20:07:15 1.Please Make sure install the driver 20:07:15 2.The Phone may be required to read and write keys 20:07:15 3.Pulled low may not, manually set. 20:08:03 Scanning USB Serial port... 20:08:13 SU2Serial Port: COM30 20:08:13 Phone detected, Wait... 20:08:14 Done. 20:08:14 Info:SPRD3 20:08:14 Initialize boot9... 20:08:15 CPU Type 8810/6820 20:08:15 Flash Type NAND 20:08:15 Flash ID 00AD00BC 20:08:15 Flash Model HYNIX H8BCS0UN0MCR 20:08:15 Flash Size 0x20000000(512.0M) 20:08:15 Starting,Wait... 20:08:24 Formating... 20:08:29 Format Done. |
02-21-2014, 21:39 | #7 (permalink) | |
Member: 1400288 Status: Offline Thanks Meter: 21 | itel it1351 ADB read backup DONE. Quote:
02-22-2014, 17:26 | #8 (permalink) |
Junior Member Join Date: Sep 2013 Location: Dodoma, Tanzania
Member: 2035604 Status: Offline Sonork: 100.1653285 Thanks Meter: 2 | would you please help me with the .pac file for itel it1351, i really need it coz i did a backup using the backup tools but i couldn't find the fdl1 and fdl2, so please help with .pac file for this phone |
01-04-2015, 13:14 | #11 (permalink) |
Freak Poster Join Date: Mar 2010 Location: IVORY COAST,abidjan
Member: 1249629 Status: Offline Thanks Meter: 28 | This is itel 1351 working fullflash DOWNLOAD THIS TO REVIVE YOUR ITEL 1351.IT IS A FULLSHASH BACKUP TESTED AND WORKING PERFECT. FLASH IT WITH PIRHANA BOX OR A BOX THAT SUPPORT BIN FILE itel 1351 android sc8810_6820_HYNIX H8BCS0UN0MCR |
03-09-2015, 14:03 | #12 (permalink) |
Junior Member Join Date: Aug 2013 Location: nairobi
Member: 2006314 Status: Offline Sonork: 10..48.53.756 Thanks Meter: 4 | itel it1351 unlock pattern done....... use miracle box and usb go to spd tab....click on read unlock and tick on clean password don't forget to select phone type spd8810/6820 tick usb and click start button...it will unlock bt the phone will not go through even if u trying to sweep key-lock...insert a pin-less Sim card it wil ask sim-card setting click on reset and set how it`s supost to be,then go back to setting, privacy and format your phone afresh ................. tested by me.... dont mind my english |
06-06-2015, 10:55 | #13 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | flash files and flash guide step by step with researchdowloader http://************************.com/...1e-flash-file/ |
