BB 9630 Reset LCD Problem , plz help........... To all.... i have BB 9630 lcd series 002 , i want to change with lcd series 004.. how to use ? i try with PBTool and special file but result still write screen... this log : Set Device to STP/Factory Mode (Upload MFI)... Needed File: MFI-24429-030 Selected File: D:\PB Tool For SmartPhone\Special File Pack\Special_File_9630 Process Start... Uploading RAM Image... Writing........................................... ....... Done. Process Start [5:51:16 AM] Connected. Boot [18x07FF15]....FAIL! Boot [08x0A01]....FAIL! Boot [0Cx02FF]....FAIL! Boot [0Cx16FF]....FAIL! Boot [1Cx80FE]....FAIL! Boot [18x07FF17]....FAIL! Boot [18x07FF18]....FAIL! Boot [1Cx80FE06]....FAIL! Boot [1Cx80FE07]....FAIL! Boot [0CxC2F0]....FAIL! Boot [60x54FE00]....FAIL! Boot [60x54FE01]....FAIL! Boot [60x54FE02]....FAIL! Clear LCD Close plz help ,,,,,,thx |
Try again with Press Set Normal Mode button and put special file then do reset lcd ! Good Luck ! Br, |
@dj.adam wait ur result, your problem solved or not? try with v0.11.25 thx |
- i try clik STP/FACTORY OS write Special_File_9630 then clik AUTO LCD button erase then flash but still white screen. - - i try clik NORMAL MODE write Special_File_9630 then clik AUTO LCD button erase then flash but still white screen. how his solution again ? |
that's mean for lcd reset BB9630 still have bugs on special file thx |
please give screenshot is that fail or OK report Br, |
http://daxin15gsm.files.wordpress.co...0030.png?w=627 RESET BLACKBERRY LCD Installers January 2013 8520.exe 8530.exe 8900.exe 8900.exe 9000-2.exe 9100-9105.exe 9300.exe 9320.exe 9330.exe 9350.exe 9360.exe 9380.exe 9500.exe 9530_2.exe 9530-3.exe 9550.exe 9670.exe 9700.exe 9780.exe 9790.exe 9800.exe 9810.exe 9860.exe 9900.exe 9930.exe 9981.exe |
@easir.comilla_e wait dj.adam reply Br, |
hey brother u have try on many others modles lcd file therefore u have facing this problem erase the set and and flash and use all procedure again and post result here with screen shot br WBGSM |
brother this is not better section for ur post plz use right section for ur post or make new thred |
this bro screenshot process FAIL... Attachment 298072 Attachment 298070 Attachment 298071 Attachment 298073 check this bro , where does the fault ? |
for BB 9630 nothing..... |
i already try erase , flash , write special file , auto lcd but result nothing ( white screen ) |
try with v0.11.25 Post screenshot for that version Br, |
yes, already try with PBtool v0.11.25 but still same... u have file reset lcd for 9630 or not ? i check in support area nothing... |
