Old 02-07-2015, 07:33   #1771 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Micromax x090 coolsand cpu read phone lock done with miracle eagle eye
MICROMAX X090 COOLSAND CPU READ PHONE LOCK DONE BY USB DATA CABLE
WITH MIRACLE EAGLE EYE
WITHOUT RX TX OTHER BOX FAIL
READ CODE
The Following User Says Thank You to jkmobile53 For This Useful Post:
Old 02-07-2015, 07:42   #1772 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Intex cloud x2 startup hang on logo solve with miracle eagle eye
INTEX CLOUD X2 STARTUP HANG ON LOGO SOLVE WITH MIRACLE EAGLE EYE
SELECT PAC FILE
WRITE DONE
Old 02-07-2015, 12:30   #1773 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
CAUTION
RESET PRIVACY LOCK AFTER IMEI NULL
IMPORTANT 1ST FULL READ BACKUP FLASH FILE AFTER ANY PROCESS
SUM TIME RESET PRIVACY LOCK/FORMAT PHONE AFTER WRITE IMEI PROBLEM
SOLUTION WRITE IMEI BEFORE (WIPE CACHE PARTITION)
THEN WRITE IMEI AT MODE WITHOUT PRESS ANY KEY
INSERT USB DATA CABLE PHONE AUTO ENABLE AT MODE
RESET PRIVACY LOCK
AFTER IMEI NULL
WRITE IMEI WITH AT MODE
READ EMMC SAVE SCATTER FILE
The Following 5 Users Say Thank You to jkmobile53 For This Useful Post:
Old 02-07-2015, 13:21   #1774 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Wing a36+ spd6803 read phone lock done with miracle eagle eye
WING A36+ SPD6803 READ PHONE LOCK DONE WITH MIRACLE EAGLE EYE
READ CODE
The Following 2 Users Say Thank You to jkmobile53 For This Useful Post:
Old 02-08-2015, 10:42   #1775 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Mmx X263 Stuck on logo/imei repair done
stuck on logo solv
  you can Set Formatting Addr
  Waiting for USB Port...
  Set MTK USB Port (COM230)
  Please Hold "ON" to connect with the phone...
  Connected to Phone.
  CPU: MT6252A(6250)_S0101 Ver: CF00  md:8B00
  Downloading Boot7 ...
  Nor/SF Flash Type: [MX] MX25U6435E
  Nor Flash Code: 00C20025(00370000)
  Nor/SF Flash Size: 0x800000 Hex Bytes
  INT/EXT RAM  Size: 0x0+0x4C000000
  Formatting Nor Flash...
  Format Start Addr: 0x768000, Size: 0x98000
>>Formatted OK.
repair imei
  if Input is space, read sn
  WARNING : IMEI CHANGE IS ILLEGAL
 Definition Applied
  Set MTK USB Port (COM235)
  CPU: MT6252 Ver: CF00  SW:0101
  Test Mode, Reading Information From the Phone...
  W IMEI1 OK: 91************
  W IMEI2 OK: 911***********
  NONE IMEI3
>>NONE IMEI4
The Following User Says Thank You to Deepesh Sharma For This Useful Post:
Old 02-08-2015, 11:00   #1776 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Micromax a36 remove google account without data lost done with miracle eagle eye
MICROMAX A36 REMOVE GOOGLE ACCOUNT JUST ONE CLICK WITHOUT ANY DATA LOST DONE
UNLOCK
Old 02-09-2015, 09:18   #1777 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
★★★ Miracle Eagle Eye Box v2.01 Beta Test Report By Miracle Team [SV] ★★★
MIRACLE EAGLE EYE BOX V2.01 BETA TEST REPORT BY MIRACLE TEAM (SV)
TEST REPORT ON NOKIA 220 MT6250/625A
PROBLEM-BLINK SOLVE BY FORMAT
MIRACLE TEAM
DONT PLAY WITH US
Plz Don,t Ask for Link Of update
Its Under Beta testing By Team
when It Will Officially Release
We Will Announce
The Following 6 Users Say Thank You to jkmobile53 For This Useful Post:
Old 02-09-2015, 11:04   #1778 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Salora e2 hang on restart solve by format with
SALORA E2 HANG ON RESTART SOLVE BY FORMAT WITH MIRACLE EAGLE EYE
NO NEED FIRMWARE
NO LOSE IMEI
MIRACLE TEAM
Old 02-09-2015, 11:20   #1779 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Clone samsung s7582 duos remove pin code read emmc done
CLONE SAMSUNG S7582 DUOS MT6572 REMOVE PIN CODE READ EMMC DONE
REMOVE PHONE PIN LOCK
READ EMMC
BR-MIRACLE TEAM
Old 02-09-2015, 11:53   #1780 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
B-fly spd6531 read privacy lock done with miracle eagle eye
B-FLY SPD6531 READ PRIVACY LOCK DONE WITH MIRACLE EAGLE EYE
MIRACLE TEAM
Old 02-09-2015, 13:09   #1781 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Karbonn a29 mt6577 remove pattern lock read scatter file done eagle eye v2.01
KARBONN A29 MT6577 REMOVE PATTERN LOCK READ SCATTER FILE DONE WITH
MIRACLE EAGLE EYE V2.01 BETA TEST REPORT
NO NEED FIRMWARE
NO NEED ADB
NO LOSE DATA
NO LOSE IMEI
READ EMMC
Old 02-09-2015, 15:56   #1782 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
G-tab p7072m 4g tab read emmc done with miracle eagle eye
G-TAB P7072M 4G TAB READ EMMC DONE WITH MIRACLE EAGLE EYE V2.01
READ INFO
READ EMMC
The Following 4 Users Say Thank You to jkmobile53 For This Useful Post:
Old 02-10-2015, 07:29   #1783 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Micromax a66 spd7710 remove google account by format with miracle eagle eye
MICROMAX A66 SPD7710 REMOVE GOOGLE ACCOUNT BY FORMAT WITH MIRACLE EAGLE EYE
NO DEAD RISK
NO HANG ON LOGO RISK
NO LOSE IMEI
NO NEED FIRMWARE
ANY TYPE LOCK REMOVE JUST FORMAT WITHOUT ANY RISK(SEE HARE FOR PROOF)
FORMAT PHONE AFTER WORKING FINE
READ FILE BIN FORMAT
FORMAT PHONE
Old 02-10-2015, 10:48   #1784 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Panasonic p55 clear-anti-theft lock by miracle eagle eye
PANASONIC P55 CLEAR-ANTI-THEFT LOCK BY MIRACLE EAGLE EYE
READ INFO
CLEAR ANTI THEFT LOCK
Old 02-10-2015, 12:01   #1785 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
PANASONIC P55 MT6583 v4.4.2 INVALID IMEI SOLVE WITH MIRACLE EAGLE EYE V2.01
SUM TIME WRITE IMEI ERROR LIKE(NONE IMEI/PORT ERROR/ATE MODE FAIL)
SOLUTION
BEFORE WRITE IMEI GO TO RECOVERY MODE THEN(WIPE CACHE DATA/WIPE USER DATA)
REBOOT PHONE AFTER WRITE IMEI WITH AT MODE TESTED SOLUTION
BEFORE WRITE IMEI READ INFO WITH ADB
BEFORE WIPE CACHE /WIPE DATA WRITE IMEI ERROR
AFTER WIPE DATA WRITE IMEI DONE
READ INFO AFTER WRITE IMEI
The Following 3 Users Say Thank You to jkmobile53 For This Useful Post:
Page generated in 0.27996 seconds with 9 queries
