03-05-2013, 10:19 | #196 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | gild s83 auto remove phone password GILD S83 AUTO REMOVE PHONE STARTUP PASSWORD READ FLASH FILE READ NV FILE NOTE- FOR BETTER HELP NOW WE READ ALL NV FILE AS POSSIBLE FOR STRONG SUPPORT FLASH AND NV FILE TEAM-MIRACLE WE CARE OUR EVERY USER'S NOTHING ELSE |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-06-2013, 12:26 | #197 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | iball i180 read code iball i180 read code coolsend cpu read flash file read nv file |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
03-08-2013, 09:45 | #199 (permalink) |
Freak Poster Join Date: Sep 2009 Location: MINDANAO
Member: 1124250 Status: Offline Thanks Meter: 62 | My Phone Q19i Logo Done By Miracle Eagle Eye [Firmware Inside] Problem: My Phone Logo Tools: Miracle Eagle Eye RJ45 Pinout Step * Set Pinout * Read Flash * Format But same Problem * Write Flash Done Same Volcano FlashFile Logs: Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.41 Update:13-01-28 S/N: >>>>>About Firmware Version:1.09 Connected OK. Connecting Internet... Network connected error Fuzzy Logic Method is very safe and reliable ! Definition Applied Definition Applied The File Information: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223_S00.E511G_MP_R1_0_V8_PHILIPPINE.BIN the file not be encrypted >> Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6223C/D_S8A00 Ver: 8A05 md:0000 CPU ID: 99400C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Type: [SPANSION] S71PL127N Nor Flash Code: 0001227E(22202200) Nor Flash Size: 0x1000000 Hex Bytes Verifying Baud... Set Baud:921600 OK. Writing(Nor)... Write OK. >>Total Time: 9 mins 0 s Here |
The Following User Says Thank You to axxes For This Useful Post: |
03-09-2013, 11:28 | #200 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Rocer r88 read screen lock code ROCKER R88 READ SCREEN LOCK CODE |
03-09-2013, 11:45 | #201 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Wing a36 read lock code WING A36 READ CODE A36 READ FLASH FILE |
The Following 6 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-09-2013, 12:57 | #202 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Meerut Age: 31
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | IPhone6S China Restart Problam Solved IPhone6S China Restart Problam Solved By Miracle Eagle Eye Br. AllChinaFiles |
The Following 2 Users Say Thank You to AllChinaFiles For This Useful Post: |
03-09-2013, 13:04 | #203 (permalink) |
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | Telego T7 Flash Read Done Telego T7 Flash Read Done By Miracle Eagle Eye Br. All China Files Last edited by AllChinaFiles; 03-09-2013 at 13:13. |
The Following User Says Thank You to AllChinaFiles For This Useful Post: |
03-09-2013, 13:14 | #204 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Wing a30 mstar cpu read code/read flash file done WING A30 MSTAR CPU READ CODE DONE READ FLASH FILE DONE FLASH FILE SIZE-132MB |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-10-2013, 06:49 | #205 (permalink) |
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | Lava Discover 135 Read Flash File Read Code Done Lava Discover 135 Read Flash File Read Code Done [IMG]http://2.bp.********.com/-EbcSIfq-wlg/UPVLK-XrTwI/AAAAAAAAAWE/eg6XHNhKJsA/s1600/lava-discover-135-white-11.jpg[/IMG] Br. All China Files |
03-10-2013, 09:44 | #207 (permalink) |
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | Lemon T49(ISP DISPLAY) Hang Pro. Solved By Format Lemon T49(ISP DISPLAY) Hang Pro. Solved By Format By Eagle Eye Format Br. AllChinaFiles |
03-11-2013, 06:30 | #208 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | vellcome ve1661 serching problem solved by write nv file vellcome ve1661 serching problem solved by write nv file CPU IMAGE BEFORE WRITE NV FILE AFTER WRITE NV FILE NOTE -ALL FILE READ FROM OTHER WORKING PHONE READ NV FILE READ FLASH FILE READ CODE BR-TEAM MIRACLE DEEPESH SHARMA |
The Following 11 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-11-2013, 07:39 | #209 (permalink) |
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | Micromax X285(MT6253) Auto On Off Remove Done Micromax X285(MT6253) Auto On Off Remove Done By Format Br. AllChinaFiles |
03-11-2013, 08:50 | #210 (permalink) |
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | Spice M-5566 Wifi Problam Solved Spice M-5566 When Click On Wifi Handset Switched On Problam Solved By Miracle Eagle Eye Format Read Code Br. ALL China Files |
