03-22-2013, 10:46 | #241 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | White cherry bl-6500 dead recovered WHITE CHERRY BL-6500 DEAD RECOVERED BY FLASHING |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-24-2013, 11:41 | #244 (permalink) |
No Life Poster Join Date: Jan 2013 Location: searching........ Age: 38
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Micromax x335 mtk 625a full sapportet in miracle eagle eye [CENTER][CENTER] SET FULLY OK ONLY MENU TOUCH NOT WORK 1ST TRY VOLCANO BOX CONNECTING OK BUT FORMAT NOT SUPPORT TRY MIRACLE EAGLE EYE FORMAT DONE MY PROBLEM SOLVE ALL OPTION WORKING OK MIRACLE IS MIRACLE set condition 1st TRY RX TX with volcano box 2nd try miracle eagle eye BR JKMOBILE53 Last edited by jkmobile53; 03-24-2013 at 11:48. Reason: 2nd image not show |
The Following 2 Users Say Thank You to jkmobile53 For This Useful Post: |
03-24-2013, 11:58 | #245 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Meerut Age: 31
Member: 1835740 Status: Offline Sonork: 100.1626589 Thanks Meter: 89 | VSun Model Rock Bluetoth+Hang On CallIng Pro. Solved VSun Model Rock Bluetoth+Hang On CallIng Problam Solved by Miracle Eagle Eye Br. AllChinaFiles |
The Following User Says Thank You to AllChinaFiles For This Useful Post: |
03-25-2013, 11:46 | #246 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | gfive u6700i blink fix by formate GFIVE U6700I BLINK FIX BY FORMATE |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
03-25-2013, 11:50 | #247 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Gfive u505 dead recovered by formate LOG HERE Definition Applied you can Set Formatting Addr Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CC01 md:8B00 Downloading Boot7 ... Nor Flash Type: [WINBOND] W25Q64DW Nor Flash Code: 00EF0060(00170000) Nor Flash Size: 0x800000 Hex Bytes Formatting Nor Flash... Format Start Addr: 0x758000, Size: 0xA8000 Formatted OK. |
03-28-2013, 07:26 | #251 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Kechoda c3 dead recover by formate KECHAODA C3 DEAD RECOVER BY FORMATE AFTER FORMATE NEED CALIBRATION BUT TUCH DAMEG THEN NEED TO WRITE LCD FILE AFTER WRITE LCD FILE REMOVE CALIBRATION SUCESSFULLY |
03-29-2013, 10:48 | #255 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Vell-com x2-02 reamove password(mtk-625 cpu) VELLCOME X2-02 REMOVE PASSWORD MTK-625 CPU READ FLASH FILE |
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post: |
