Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1771 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: searching........ Age: 37
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Micromax x090 coolsand cpu read phone lock done with miracle eagle eye MICROMAX X090 COOLSAND CPU READ PHONE LOCK DONE BY USB DATA CABLE WITH MIRACLE EAGLE EYE WITHOUT RX TX OTHER BOX FAIL READ CODE ![]() ![]() ![]() Last edited by Anil_Kumrawat; 02-07-2015 at 07:39. |
The Following User Says Thank You to jkmobile53 For This Useful Post: |
![]() | #1772 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Intex cloud x2 startup hang on logo solve with miracle eagle eye INTEX CLOUD X2 STARTUP HANG ON LOGO SOLVE WITH MIRACLE EAGLE EYE SELECT PAC FILE ![]() WRITE DONE ![]() ![]() |
![]() | #1773 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | CAUTION RESET PRIVACY LOCK AFTER IMEI NULL IMPORTANT 1ST FULL READ BACKUP FLASH FILE AFTER ANY PROCESS SUM TIME RESET PRIVACY LOCK/FORMAT PHONE AFTER WRITE IMEI PROBLEM SOLUTION WRITE IMEI BEFORE (WIPE CACHE PARTITION) THEN WRITE IMEI AT MODE WITHOUT PRESS ANY KEY INSERT USB DATA CABLE PHONE AUTO ENABLE AT MODE ![]() RESET PRIVACY LOCK ![]() AFTER IMEI NULL ![]() WRITE IMEI WITH AT MODE ![]() READ EMMC SAVE SCATTER FILE ![]() ![]() |
The Following 5 Users Say Thank You to jkmobile53 For This Useful Post: |
![]() | #1774 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Wing a36+ spd6803 read phone lock done with miracle eagle eye WING A36+ SPD6803 READ PHONE LOCK DONE WITH MIRACLE EAGLE EYE READ CODE ![]() |
The Following 2 Users Say Thank You to jkmobile53 For This Useful Post: |
![]() | #1775 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,284 ![]() | Mmx X263 Stuck on logo/imei repair done stuck on logo solv Code: you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM230) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CF00 md:8B00 Downloading Boot7 ... Nor/SF Flash Type: [MX] MX25U6435E Nor Flash Code: 00C20025(00370000) Nor/SF Flash Size: 0x800000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Formatting Nor Flash... Format Start Addr: 0x768000, Size: 0x98000 >>Formatted OK. Code: if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Definition Applied Waiting for USB Port... Set MTK USB Port (COM235) Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CF00 SW:0101 Test Mode, Reading Information From the Phone... W IMEI1 OK: 91************ W IMEI2 OK: 911*********** NONE IMEI3 >>NONE IMEI4 |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
![]() | #1776 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Micromax a36 remove google account without data lost done with miracle eagle eye MICROMAX A36 REMOVE GOOGLE ACCOUNT JUST ONE CLICK WITHOUT ANY DATA LOST DONE WITH MIRACLE EAGLE EYE UNLOCK ![]() ![]() |
![]() | #1777 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | ★★★ Miracle Eagle Eye Box v2.01 Beta Test Report By Miracle Team [SV] ★★★ MIRACLE EAGLE EYE BOX V2.01 BETA TEST REPORT BY MIRACLE TEAM (SV) TEST REPORT ON NOKIA 220 MT6250/625A PROBLEM-BLINK SOLVE BY FORMAT ![]() BR MIRACLE TEAM DONT PLAY WITH US Plz Don,t Ask for Link Of update Its Under Beta testing By Team when It Will Officially Release We Will Announce Last edited by jkmobile53; 02-09-2015 at 09:20. Reason: ADD WORD |
The Following 6 Users Say Thank You to jkmobile53 For This Useful Post: |
![]() | #1778 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Salora e2 hang on restart solve by format with SALORA E2 HANG ON RESTART SOLVE BY FORMAT WITH MIRACLE EAGLE EYE NO NEED FIRMWARE NO LOSE IMEI ![]() BR MIRACLE TEAM ![]() Last edited by Anil_Kumrawat; 02-09-2015 at 12:05. Reason: add image |
![]() | #1779 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Clone samsung s7582 duos remove pin code read emmc done CLONE SAMSUNG S7582 DUOS MT6572 REMOVE PIN CODE READ EMMC DONE WITH MIRACLE EAGLE EYE REMOVE PHONE PIN LOCK JUST ONE CLICK WITHOUT ANY DATA LOST ![]() READ EMMC ![]() BR-MIRACLE TEAM ![]() Last edited by Anil_Kumrawat; 02-09-2015 at 12:04. Reason: add image |
![]() | #1780 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | B-fly spd6531 read privacy lock done with miracle eagle eye Last edited by Anil_Kumrawat; 02-09-2015 at 12:04. |
![]() | #1781 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Karbonn a29 mt6577 remove pattern lock read scatter file done eagle eye v2.01 KARBONN A29 MT6577 REMOVE PATTERN LOCK READ SCATTER FILE DONE WITH MIRACLE EAGLE EYE V2.01 BETA TEST REPORT NO NEED FIRMWARE NO NEED ADB NO LOSE DATA NO LOSE IMEI ![]() READ EMMC ![]() ![]() |
![]() | #1782 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | G-tab p7072m 4g tab read emmc done with miracle eagle eye G-TAB P7072M 4G TAB READ EMMC DONE WITH MIRACLE EAGLE EYE V2.01 READ INFO ![]() READ EMMC ![]() ![]() Last edited by jkmobile53; 02-09-2015 at 15:58. Reason: add link |
The Following 4 Users Say Thank You to jkmobile53 For This Useful Post: |
![]() | #1783 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Micromax a66 spd7710 remove google account by format with miracle eagle eye MICROMAX A66 SPD7710 REMOVE GOOGLE ACCOUNT BY FORMAT WITH MIRACLE EAGLE EYE NO DEAD RISK NO HANG ON LOGO RISK NO LOSE IMEI NO NEED FIRMWARE ANY TYPE LOCK REMOVE JUST FORMAT WITHOUT ANY RISK(SEE HARE FOR PROOF) FORMAT PHONE AFTER WORKING FINE ![]() READ FILE BIN FORMAT ![]() FORMAT PHONE ![]() ![]() Last edited by jkmobile53; 02-10-2015 at 07:32. Reason: BIG IMAGE |
![]() | #1784 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Panasonic p55 clear-anti-theft lock by miracle eagle eye PANASONIC P55 CLEAR-ANTI-THEFT LOCK BY MIRACLE EAGLE EYE READ INFO ![]() CLEAR ANTI THEFT LOCK ![]() ![]() |
![]() | #1785 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | PANASONIC P55 MT6583 v4.4.2 INVALID IMEI SOLVE WITH MIRACLE EAGLE EYE V2.01 PANASONIC P55 MT6583 v4.4.2 INVALID IMEI SOLVE WITH MIRACLE EAGLE EYE V2.01 SUM TIME WRITE IMEI ERROR LIKE(NONE IMEI/PORT ERROR/ATE MODE FAIL) SOLUTION BEFORE WRITE IMEI GO TO RECOVERY MODE THEN(WIPE CACHE DATA/WIPE USER DATA) REBOOT PHONE AFTER WRITE IMEI WITH AT MODE TESTED SOLUTION BEFORE WRITE IMEI READ INFO WITH ADB ![]() BEFORE WIPE CACHE /WIPE DATA WRITE IMEI ERROR ![]() AFTER WIPE DATA WRITE IMEI DONE ![]() READ INFO AFTER WRITE IMEI ![]() ![]() |
The Following 3 Users Say Thank You to jkmobile53 For This Useful Post: |
