Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #406 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,284 ![]() | Kenxinda f500 read code in rx tx mode KENXINDA F500 SPD 6600L CPU CHARGING JACK DAMEG READ PASSWORD IN RX TX MODE ![]() TRULY FOR CHINA |
![]() | #411 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,284 ![]() | Intex force mtk 625 cpu readcode/flash file INTEX FORCE ![]() MTK 625 CPU READ FLASH FILE ![]() READ PHONE CODE ![]() |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
![]() | #412 (permalink) |
Major Poster ![]() ![]() Join Date: Jul 2011 Location: Russia
Member: 1615277 Status: Offline Thanks Meter: 11 | confirm data 2013 07 12 14:10 (and we now have in the Tomsk 19:09) =========== Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.51 Update:13-06-24 S/N: >>>>>About Firmware Version:1,10 Connected OK. Connecting Internet... Network connected error Fuzzy Logic Method is very safe and reliable ! MTKScaning Pinouts,Please press Power-Key... << Scan pinouts Error,ID: San_Pouts_001 << OK. type: MTK Model:625A Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor Flash Code: 00C20025(00380000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Verifying Baud... Set Baud:921600 OK. Reading infr(Nor)... The phone information: C5H_SD_S922A_WI_ATV_W4_PCB01_GPRS_MT6250_S00.F1_0. BIN the file not be encrypted Done. Please Hold "ON" to connect with the phone... Definition Applied Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor Flash Code: 00C20025(00380000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... The phone information: C5H_SD_S922A_WI_ATV_W4_PCB01_GPRS_MT6250_S00.F1_0. BIN the file not be encrypted Read OK. Total time: 3 mins 14 s File Save to: C:\Documents and Settings\Андрей\Мои документы\C5H_SD_S922A_WI_ATV_W4_PCB01_GPRS_MT6250 _S00.F1_0.BIN Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT625A Ver: CA01 SW:0001 Test Mode, Reading Information From the Phone... Formatting as a safe mode OK ! (items= 105) if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Definition Applied Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT625A Ver: CA01 SW:0001 Test Mode, Reading Information From the Phone... W IMEI1 OK: 356587457ххх55-9 W IMEI2 OK: 356587457ххх01-6 NONE IMEI3 NONE IMEI4 |
The Following User Says Thank You to ermak-72 For This Useful Post: |
![]() | #413 (permalink) |
Member: 1615277 Status: Offline Thanks Meter: 11 | today have been successfully reset passwords on graphics SPD ------------------------ Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.51 Update:13-06-24 S/N: >>>>>About Firmware Version:1,10 ------------------------ Scanning USB Serial port... SU2Serial Port: COM252 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot13... CPU type: 8810/6820 Flash type: NAND Flash ID: 002C00BC Flash Model: Micron MT29C4G48MAZAPAKD Flash Size: 0x20000000(512,0M) Formating... >>Format Completed. ---------------------------- Scanning USB Serial port... SU2Serial Port: COM183 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot13... CPU type: 8810/6820 Flash type: NAND Flash ID: 009800BC Flash Model: TOSHIBA H8BCS0UN0MCR Flash Size: 0x20000000(512,0M) Formating... Format Completed. ---------------------- identified the type of flash. and each model was made with two pieces. all work. everything is fine! |
![]() | #417 (permalink) |
Member: 1615277 Status: Offline Thanks Meter: 11 | phone with exceeded the number of password. recovere not normal. wipe impossible --------------- Hardware : MT6575 (SMDK4X12 is Fake!) Model : GT-N7100 Build number : S005_SSD_XLS_L001 Build date UTC : 20130305-020941 Android v : 4.1.2 Baseband v: MAUI.11AMD.W12.22.SP.V8, 2012/12/28 20:25 Kernel v : 3.0.13 ([email protected]) (gcc version 4.4.3 (GCC) ) #1 Wed Mar 6 09:33:18 CST 2013 Uboot build v : MAIN2.2.ubt.3908 LCD Driver IC : 1-nt35510_mcu ================== Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM45) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6575 SW: E201 Ver: CB00 Downloading Boot8 ... Nand Flash Type: [Micron] MT29F4G16 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading Size: 0x21000000 Reading infr(Nand)... Done. ------------------- android tab - reset gmail Connecting to Phone,Wait..ok Reset Gmail... Communicate Error, id:21 Communicate Error, id:61 Connecting to Phone,Wait..ok Reset Gmail... >>Done. ================== all data and contacts all over the place!! |
![]() | #419 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,284 ![]() | Yxtel w666(coolsend cpu) YXTEL W666 COOLSEND CPU READ FLASH FILE ![]() READ CODE ![]() |
The Following 5 Users Say Thank You to Deepesh Sharma For This Useful Post: |
