Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #496 (permalink) |
Moderator ![]() Join Date: Nov 2009 Location: South Africa > Bangladesh Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | ![]() Bro:- Palash Ahammad |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #497 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,288 ![]() | By2 n58(coolsend cpu) read code/flash file BY2 N58(COOLSEND CPU) READ PHONE CODE ![]() READ FLASH FILE ![]() IN NEW UPDATE 1.56 ADD MORE NEW COOLSEND FLASH ID ![]() FEEL THE MAGIC OF MIRACLE-TEAM PRODUCT |
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post: |
![]() | #498 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: searching........ Age: 38
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Mtk6260 file read & write done with miracle eagle eye READ FILE ![]() WRITE FILE ![]() br jkmobile53 |
The Following 4 Users Say Thank You to jkmobile53 For This Useful Post: |
![]() | #499 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Yestel M311 Coolsand CPU Flash Write Done 1'st read blinking file for recondition backup than write flash from fresh set flash file very easy by Miracle eagle eye. ![]() Bro:- Palash Ahammad |
![]() | #500 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Micromax X295 Phone Lock Remove'' Before Format Must Be Need Backup File Read ![]() Bro:- Palash Ahammad |
![]() | #501 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | ![]() [IMG]http://2.bp.********.com/-mujqYv7s52c/UQ5awXykP4I/AAAAAAAABmU/kUxs27o-JgU/s320/w30.png[/IMG] Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.56 Update:13-08-12 S/N: >>>>>About Firmware Version:1.10 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! 1.Phone Power off 2.Add SU, is for not normally Root, you can choose this 3.Clear code for USB debugging can not manually open 4.With clear code function Cleared password, please recover ROOT Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM30) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6575 SW: E201 Ver: CB00 Downloading Boot8 ... Nand Flash Type: [Micron] MT29F4G16 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading ROOT DATA...480000_500000 C:\Program Files\Miracle_EagleEye\MTK6575nandboot1308241310.img Writing ROOT DATA...480000_500000 Root OK. total: 0 mins41 s Connecting to Phone,Wait..ok Reset Gmail... >>Done. ![]() Bro:- Palash Ahammad |
![]() | #502 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Symphony FT03 Format & IMEI Repair Done Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.56 Update:13-08-12 S/N: >>>>>About Firmware Version:1.10 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: D100 md:8B00 Downloading Boot7 ... Nor Flash Code: 00C20025(00370000) Nor/SF Flash Size: 0x800000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Formatting Nor Flash... Format Start Addr: 0x750000, Size: 0xB0000 Formatted OK. if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Definition Applied Please Hold "ON" to connect with the phone... Abort by User Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: D100 SW:0101 Test Mode, Reading Information From the Phone... W IMEI1 OK: 35640101414759-9 W IMEI2 OK: 35640101414758-1 NONE IMEI3 >>NONE IMEI4 Bro:- Palash Ahammad |
![]() | #503 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Symphony FT04 Format & IMEI Repair Done Code: S/N: >>>>>About Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.56 Update:13-08-12 Firmware Version:1.10 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! Definition Applied you can Set Formatting Addr Waiting for USB Port... Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A(6250)_S0101 Ver: CA05 md:8B00 Downloading Boot7 ... Nor Flash Code: 00C20025(00370000) Nor/SF Flash Size: 0x800000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Formatting Nor Flash... Format Start Addr: 0x758000, Size: 0xA8000 Formatted OK. if Input is space, read sn WARNING : IMEI CHANGE IS ILLEGAL Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CA05 SW:0101 Test Mode, Reading Information From the Phone... W IMEI1 OK: 35740504663694-0 W IMEI2 OK: 35740504663695-7 NONE IMEI3 >>NONE IMEI4 Bro:- Palash Ahammad |
![]() | #504 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Symphony FT40 Logo Hung Done By Format ![]() Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.56 Update:13-08-12 S/N: >>>>>About Firmware Version:1.10 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM126) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6236_S8A00 Ver: 8A03 md:0000 Downloading Boot6 ... Nand Flash Type: [HYNIX] HYD0SQG0MF1P Nand Flash Code: 00AD00B1(00800055) Nand Flash Size: 0x8400000 Hex Bytes INT/EXT RAM Size: 0x18000+0x4000000 Formatting Nand Flash... Format Satrt Addr??0x4000000, Size: 0x4000000 Nand bad Block: 1 >>Format nand OK Bro:- Palash Ahammad |
![]() | #505 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Symphony D51 blinking Repair Done Code: Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.56 Update:13-08-12 S/N: >>>>>About Firmware Version:1.10 Connected OK. Please check the network. Fuzzy Logic Method is very safe and reliable ! Definition Applied Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor Flash Code: 00EF0060(00180000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Reading(Nor)... The phone information: HONGYU50_FTE_11B_PCB01_GPRS_MT6250_S00.SYMPHONY_D51_C381J2A_S09_130402.BIN the file not be encrypted Read OK. Total time: 0 mins 48 s File Save to: C:\Documents and Settings\786\My Documents\Symphony D51\HONGYU50_FTE_11B_PCB01_GPRS_MT6250_S00.SYMPHONY_D51_C381J2A_S09_130402.BIN Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Unstable comport Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor Flash Code: 00EF0060(00180000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Formatting Nor Flash... Format Start Addr: 0xCB0000, Size: 0x340000 >>Formatted OK. ![]() Bro:- Palash Ahammad |
![]() | #508 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,073 | Symphony FT02i Logo Hung Done By Format ![]() Bro:- Palash Ahammad |
![]() | #509 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,288 ![]() | Micromax x263 dead recover MICROMAX X263 DEAD RECOVER ![]() |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
![]() | #510 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,288 ![]() | Micromax q6 blink fix and read flash file MICROMAX Q6 BLINK FIX ![]() AFTER SOLV READ FLASH FILE ![]() |
