Old 09-22-2013, 13:30   #541 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,053
Symphony M40 Hung Repair Done By Format
  Definition Applied
  you can Set Formatting Addr
  Waiting for USB Port...
  Set MTK USB Port (COM186)
  Please Hold "ON" to connect with the phone...
  Connected to Phone.
  CPU: MT6252A(6250)_S0101 Ver: CE00  md:8B00
  Downloading Boot7 ...
  Nor Flash Code: 00EF0060(00170000)
  Nor/SF Flash Size: 0x800000 Hex Bytes
  INT/EXT RAM  Size: 0x0+0x4C000000
  Formatting Nor Flash...
  Format Start Addr: 0x750000, Size: 0xB0000
>>Formatted OK.
Bro:- Palash Ahammad
Old 09-22-2013, 13:32   #542 (permalink)
Moderator
Member: 1162626
Micromax X222 Hung Logo & IMIE Repair Done
  Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
  SoftWare Version 1.57  Update:13-08-24
  S/N: >>>>>About
  Firmware Version:1.10
  Connected OK.
  Please check the network.
  Fuzzy Logic Method is very safe and reliable !
  Definition Applied
  Connected to Phone.
  Nor Flash Code: 00C20025(00370000)
  Format Start Addr: 0x740000, Size: 0xC0000
  Formatted OK.
  if Input is space, read sn
  WARNING : IMEI CHANGE IS ILLEGAL
  CPU: MT6252 Ver: CE00  SW:0101
  Test Mode, Reading Information From the Phone...
  W IMEI1 OK: 35455801841083-6
  W IMEI2 OK: 35455801841084-4
  NONE IMEI3
>>NONE IMEI4
Old 09-22-2013, 13:37   #543 (permalink)
Moderator
Member: 1162626
Micromax x1i-Xtra Dead Recovery Done By With Flash
Old 09-22-2013, 13:40   #544 (permalink)
Moderator
Member: 1162626
Symphony D56 Blinking Done By Format
Old 09-22-2013, 13:45   #545 (permalink)
Moderator
Member: 1162626
Nokia MBO FM Restore Image Defaults Done By Format
  S/N: >>>>>About
  Connected OK.
  Definition Applied
  Set MTK USB Port (COM6)
  Connected to Phone.
  CPU: MT6252A(6250)_S0101 Ver: CF00  md:8B00
  Reading(Nor)...
  The phone information:
  T285_PCB01_GPRS_MT6252_S01.MAUI_10A_W11_08_MP_V4_F4.BIN
  the  file not be encrypted
  Read OK.
  Total time: 0 mins 23 s
  File Save to: C:\Documents and Settings\786\Desktop\New Folder (2)\GAOPHONE60A_COSMOS_11B_PCB01_GPRS_MT6260_S00.E620YXAR141306211414.BIN
  Definition Applied
  Connected to Phone.
  Format Start Addr: 0x768000, Size: 0x98000
>>Formatted OK.
Old 09-22-2013, 13:47   #546 (permalink)
Moderator
Member: 1162626
Maximus M307m Flash Repair Done
  S/N: >>>>>About
  Connected OK.
  MTK SF File: MT625A/6260
  The File Information:
  DEWAV50D_OVERSEA_11B_H3256_PCB01_GPRS_MT6250_S00.H3256_S100_MAXIMUS_M307M_L103.BIN
  none usbport, maybe driver not installed
  Set MTK USB Port (COM142)
  Connected to Phone.
  CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01  md:8000
  Nor Flash Code: 00EF0040(00160000)
  Nor/SF Flash Size: 0x400000 Hex Bytes
  INT/EXT RAM  Size: 0x0+0x0
  The file be proceeded
  Erasing...63
  Writing(Nor)...
  Write OK.
>>Total Time: 1 mins 3 s
Old 09-22-2013, 13:49   #547 (permalink)
Moderator
Member: 1162626
KIngstar C20 Read Flash Done
Tool)
  S/N: >>>>>About
  Connected OK.
  Scaning Chip-Type,Please press Power-Key...
  OK. Spread
  Definition Applied
  Definition Applied
  Scanning USB Serial port...
  SU2Serial Port: COM151
  Connecting to Phone,Wait..
  Done.
  Infor: Spreadtrum Boot Block version 2.0
  Initialize boot10...
  CPU    type: 6610
  Flash  type: NOR
  Flash    ID: 00C20025(00370000)
  Flash Model: MX25U6435E
  Flash  Size: 0x800000(8.0M)
  reading,Wait...
  Read Completed.
>>File save to: C:\Documents and Settings\786\Desktop\KIngstar c20\6610_MX25U6435E.bin
Old 09-22-2013, 13:52   #548 (permalink)
Moderator
Member: 1162626
Micromax x455 Hung Provlem Done By Fresh File With Flash
  S/N: >>>>>About
  Connected OK.
  count:=0_
  None SU2Serial Port.
  1.Please Make sure install the driver
  2.The Phone may be required to read and write keys
  3.Pulled low may not, manually set.
  SU2Serial Port: COM165
  Done.
  Infor: SPRD3
  Initialize boot9...
  CPU    type: 6531A
  Flash  type: NOR
  Flash    ID: 00C80060(00180000)
  Flash Model: GD27LQ128
  Flash  Size: 0x1000000(16.0M)
  Being analyzed,Wait...
  IMEI1 :911325601343493
  IMEI2 :911325601343501
  IMEI3 :358570010103893
  IMEI4 :910575601400468
  Unlock  Code: 0000
>>Privacy  Code: 0000
  Done.
  Infor: SPRD3
  Initialize boot9...
  CPU    type: 6531A
  Flash  type: NOR
  writing,Wait...
>>Write Completed.
Old 09-24-2013, 06:19   #549 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Carlvo m6 blink fix
CARLVO M6 BLINK FIX BY FORMATE ONLY
COOLSEND CPU
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 09-24-2013, 12:53   #550 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Intex coud x2 dead recover
INTEX COUD X2
DEAD RECOVER (ONLY VIBERATE)
WITH
FLASH OG PAC FILE
USING MIRACLE EAGLE-EYE
REALY NO ANY ONE COMPARE WITH US
The Following 10 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 09-25-2013, 08:21   #551 (permalink)
Moderator
Member: 1162626
Symphony B4 Blinking Done By Format
  S/N: >>>>>About
  Connected OK.
  Definition Applied
  Connected to Phone.
  Format Start Addr: 0x3B3000, Size: 0x4D000
>>Formatted OK.
Old 09-25-2013, 11:05   #552 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Miracle magic again coolsend searching problem solved
MIRACLE MAGIC AGAIN
CARLVO A22(COOLSEND CPU)
SEARCHING PROBLEM SOLVED
BY WRITE NV FILE ONLY
REALY MIRACLE IS MIRACLE-BOX
TEAM-MIRACLE
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 09-27-2013, 06:03   #553 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Micromax q2+ ead recover
MICROMAX Q2+ DEAD RECOVER
WITH FORMATE ONLY
Old 09-27-2013, 06:05   #554 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Sumtel s2 read phone code
SUMTEL S2
COOLSEND CPU
READ PHONE CODE
Old 09-27-2013, 09:18   #555 (permalink)
Moderator
Member: 1162626
Symphony B2 Blinking Done By Format
  S/N: >>>>>About
  Connected OK.
  Definition Applied
  Connected to Phone.
  Nor/SF Flash Size: 0x300000 Hex Bytes
  Format Start Addr: 0x2CE000, Size: 0x32000
>>Formatted OK.
Page generated in 0.27186 seconds with 9 queries
