07-28-2014, 17:53 | #1 (permalink) |
Banned Join Date: Mar 2010 Location: Okara Pakistan Age: 47
Member: 1273573 Status: Offline Sonork: 100.1623251 QQ.2905713135 Thanks Meter: 3,780 | Eid Mubarak To All My GSM Reember Miracle Team Wish you An Happy EID To All My GSM Reember Eid Mubarak WE ALWAYS CARE OUR USER FIGHTER CAN FIGHT (:::::::::::::::::[FEEL THE POWER OF ]:::::::::::::::: (:::::::::::::::::[MIRACLE TEAM ]:::::::::::::::: |
The Following 7 Users Say Thank You to zulfqarali For This Useful Post: |
07-28-2014, 18:31 | #2 (permalink) |
Freak Poster Join Date: Jul 2010 Location: LOVE TO ALL OVER MY HART TUCH Age: 52
Member: 1353395 Status: Offline Sonork: 100.1607424 Thanks Meter: 101 | Ae Eid k Chand Jab Wo Teri Taraf Dekhain To Unhain Kuch Yaad Dilana. Aur Kehna … Tumhain Koi Yaad Karta Hai. Teri Arzoo, Teri Umeed Karta Hai. Koi Aaj Bhi Tumhain Dekh Kar Eid Karta Hai. |
The Following 4 Users Say Thank You to ifi786786 For This Useful Post: |
07-28-2014, 18:41 | #3 (permalink) |
Junior Member Join Date: Aug 2009 Location: Bangalore Age: 42
Member: 1093036 Status: Offline Sonork: rainkum Thanks Meter: 2 | MOTO G Hard reset 10 Easy Steps Back to Previous Page How do I reset my device? In the unlikely event that your device becomes unresponsive, frozen, blank or black screen, or will not respond to the power button, you can perform a force restart or reboot on the device by following the steps below. Press and hold the Power button for 7 - 10 seconds, the device will restart and go through the boot-up sequence. Notes: The forced restart or reboot will not delete any Data on your phone. If completing the 7-10 second Reset does not recover normal functionality of the device, then press and hold the Power Button for a full 120 seconds while connected to a charger. Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature everything is deleted. To reset your device: 1. Touch Image 2. Touch Settings 3. Touch Backup & reset 4. Touch Factory Data Reset 5. Touch Reset Phone External Reset If you are unable to access the phone's menu to perform the standard reset you can attempt an external factory reset. Notes: When using this feature; everything is deleted from the device. Reset will require a minimum battery level of 25%. If you are unable to perform a reset, please charge for 20-30 minutes and try reset again. 1. With the phone powered off, press the VOL DOWN KEY for 2-3 seconds then POWER key then release. 2. The device will display different BOOT OPTIONS 3. Use the VOL DOWN Key to SCROLL to Recovery and VOL UP Key to select Tip: If the device reboots, you may have waited to long to make a selection, you will need to begin the process again. 4. The device will display the Motorola logo and then the Android in distress ( logo with Exclamation mark) 5. Press and hold the VOL UP key for 10-15 seconds. While still holding the VOL UP key tap and release the POWER key Tip: You can try this step, holding the phone in landscape. If you are stuck on step 6, try a force reboot by pressing the Power key and Vol Down key, and start the process again. 6. The device will display additional menu options (Text will appear in BLUE) 7. Use the VOL DOWN Key to scroll to Wipe data / factory reset and the POWER Key to select this option 8. Use the VOL DOWN key again to select YES - delete all user data and press the POWER key to CONFIRM 9. Once the Formatting is complete, press the POWER key to confirm a REBOOT 10. The device will reboot and start the normal power up sequence |
The Following User Says Thank You to rainkum For This Useful Post: |
