08-27-2015, 10:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | miracle eagle eye not open with+key>>>>> can any supporter solve my problem????? [email protected] whatsup number- 09936182923 |
08-27-2015, 17:21 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Quote:
First uninstall Miracle Eagle Eye From Control Panel. Then Delete The Folder From C:\Program Files\Miracle Eagle Eye. Restart Computer. First Install PL2303_Prolific_Driver. Then Connect Box With Miracle Key. Wait For Install Auto 2303 Driver & Key Driver. Then Run Latest Setup 2.15. You Must Done. (Must Install Microsoft.net Framework 2.0 to 4.0) | |
The Following 11 Users Say Thank You to swapan For This Useful Post: |
08-27-2015, 23:54 | #4 (permalink) |
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Re (New Setup 2.16) Download Latest Setup 2.16 From Here. Miracle Eagle Eye ver 2.16 │ MTK 6595 Full Support│SCI 7730 Support Format (27/08/15) After Setup Complite. If Need Update Dongole. Then Go To About Tab, Repair Firmware. Disconnect Box & Key Connect Again Box & Key. Then Run Miracle Eagle Eye. That's All........ Last edited by swapan; 08-27-2015 at 23:59. |
The Following 7 Users Say Thank You to swapan For This Useful Post: |
08-29-2015, 10:52 | #5 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
I said my box does not open after install miracle eagle eye with pkey. Did you understand bro????????? I use miracle box first and i purcharsed miracle eagle eye box too with new pkey. I try with other pc and after formate my pc but miracle eagle eye doesnt open. Look above. | |
08-29-2015, 11:46 | #6 (permalink) | |
Check Prolific USB-to-Serial Comm Port PL-2303 Driver Not Show | |
The Following 4 Users Say Thank You to swapan For This Useful Post: |
08-29-2015, 12:37 | #7 (permalink) |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Swapan bro i am adeel. You know me. As you said PL2303 driver not show .bro for your kind information all driver are ok. You watched in my image ,i did not open com port as you look better. There is no any problem in driver. Now what to do. |
The Following User Says Thank You to mahzra azra For This Useful Post: |
08-29-2015, 13:42 | #9 (permalink) |
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Ok Brother. Add My Listed Messenger Or Any Product Supporter [PS] . We Will Check Remotely.............. |
08-29-2015, 15:41 | #10 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I Recommend To You Just Flow This Solution http://forum.gsmhosting.com/vbb/11246831-post83.html Best Regard Br Palash Ahammad
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
08-31-2015, 05:04 | #11 (permalink) | |
i can disturbed doing many tricks for install eagle eye. my contect number is above. thanks. | |
08-31-2015, 18:06 | #13 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote: | |
