Old 08-27-2015, 10:49   #1 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
miracle eagle eye not open with+key>>>>>
i installed 2.15 and with new pkey and when i open miracle eagle eye it says box not connected. look it-----
can any supporter solve my problem?????
[email protected]
whatsup number- 09936182923
Old 08-27-2015, 11:21   #2 (permalink)
Member: 2060387
Sonork: 100.1646319:23
install another or cheek pl driver.
Old 08-27-2015, 17:21   #3 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Cool
[email protected]
First uninstall Miracle Eagle Eye From Control Panel.
Then Delete The Folder From C:\Program Files\Miracle Eagle Eye.
Restart Computer. First Install PL2303_Prolific_Driver. Then Connect Box With Miracle Key. Wait For Install Auto 2303 Driver & Key Driver.
Then Run Latest Setup 2.15. You Must Done. (Must Install Microsoft.net Framework 2.0 to 4.0)
The Following 11 Users Say Thank You to swapan For This Useful Post:
Old 08-27-2015, 23:54   #4 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile Re (New Setup 2.16)
Download Latest Setup 2.16 From Here.
Miracle Eagle Eye ver 2.16 │ MTK 6595 Full Support│SCI 7730 Support Format (27/08/15)
After Setup Complite. If Need Update Dongole. Then Go To About Tab, Repair Firmware.
Disconnect Box & Key Connect Again Box & Key. Then Run Miracle Eagle Eye.
That's All........
The Following 7 Users Say Thank You to swapan For This Useful Post:
Old 08-29-2015, 10:52   #5 (permalink)
Member: 1722956
Thanks Meter: 305
Originally Posted by swapan View Post
download latest setup 2.16 from here.
miracle eagle eye ver 2.16 │ mtk 6595 full support│sci 7730 support format (27/08/15)
after setup complite. If need update dongole. Then go to about tab, repair firmware.
Disconnect box & key connect again box & key. Then run miracle eagle eye.
That's all........
bro i think you did not read my post carefully.
I said my box does not open after install miracle eagle eye with pkey.
Did you understand bro?????????
I use miracle box first and i purcharsed miracle eagle eye box too with new pkey.
I try with other pc and after formate my pc but miracle eagle eye doesnt open. Look above.
Old 08-29-2015, 11:46   #6 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile
Check Prolific USB-to-Serial Comm Port
PL-2303 Driver Not Show
The Following 4 Users Say Thank You to swapan For This Useful Post:
Old 08-29-2015, 12:37   #7 (permalink)
Member: 1722956
Thanks Meter: 305
Swapan bro i am adeel. You know me.
As you said PL2303 driver not show .bro for your kind information all driver are ok.
You watched in my image ,i did not open com port as you look better.
There is no any problem in driver.
Now what to do.
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 08-29-2015, 12:42   #8 (permalink)
Member: 1722956
Thanks Meter: 305
LOOK IT BRO---
Old 08-29-2015, 13:42   #9 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile
Ok Brother.
Add My Listed Messenger Or Any Product Supporter [PS] . We Will Check Remotely..............
Old 08-29-2015, 15:41   #10 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
LOOK IT BRO---
I Recommend To You Just Flow This Solution
http://forum.gsmhosting.com/vbb/11246831-post83.html
Best Regard
Palash Ahammad
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 08-31-2015, 05:04   #11 (permalink)
Member: 1722956
Thanks Meter: 305
Best Regard
Palash Ahammad
bro can you do it via tv????
i can disturbed doing many tricks for install eagle eye.
my contect number is above.
thanks.
Old 08-31-2015, 15:36   #12 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
@mahzra azra
Sure i can do it
plz contact me or any ps of miracle box
Yahoo [email protected]
The Following User Says Thank You to jkmobile53 For This Useful Post:
Old 08-31-2015, 18:06   #13 (permalink)
Member: 1722956
Thanks Meter: 305
Originally Posted by jkmobile53 View Post
@mahzra azra
Sure i can do it
Ok i will join you on yahoomassanger tomorrow.
Old 08-31-2015, 18:22   #14 (permalink)
swapan's Avatar
Member: 330460
Sonork: (Off Line)
Thanks Meter: 6,479
Smile
adeel
add me.. I will try to solve ur problem
The Following 2 Users Say Thank You to swapan For This Useful Post:
Old 09-02-2015, 05:53   #15 (permalink)
Member: 1722956
Thanks Meter: 305
any one here to solve my problem?????
where are product supporter???
what to do of this box????
do i through this box???
Page generated in 0.38314 seconds with 8 queries
