05-23-2015, 12:53 | #1 (permalink) |
Banned Join Date: Mar 2010 Location: Okara Pakistan Age: 47
Member: 1273573 Status: Offline Sonork: 100.1623251 QQ.2905713135 Thanks Meter: 3,780 | All SPD & ALL MTK CPU USB NOT DETECTED SOLUTION STEP BY STEP BY MIRACLE TEAM All SPD & ALL MTK CPU USB NOT DETECTED SOLUTION STEP BY STEP BY MIRACLE TEAM SPD 6531 Bar Phone & SPD 8810 Android Phone Finding Of Boot Key For Spd First Of All Insert Batrry And Wait 5 to 10 Second And Then Press And Hold Check One By One All Keys And Press Power Key If Set Is Going To On Then It Is Not Boot Key If Set Is Not On Till 5 Seconds Then This Is Boot Key & Manual Pinouts Slect For Spd 6531 Check This Gif Video All SPD & ALL MTK CPU BAR & ANROID PHONE If Usb Jack Is Damaged Or Not Detected Then Cut Usb Cable And Sold It Wires On Board explain Here With New User Usb Jack Is Damaged If Pc Show Usb Not Recognised Then Change , Dp-, Dm+ Wire With Eachother Br, Miracle Team |
The Following 30 Users Say Thank You to zulfqarali For This Useful Post: |
05-24-2015, 09:30 | #3 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2263794 Status: Offline Thanks Meter: 1 | Helpful solution thanks zulfqarali (JAMIMOBILE) Helpful solution thanks zulfqarali (JAMIMOBILE) Mehtab Mobiles Thari Mirwah 03003726456 |
The Following User Says Thank You to mehtab.mobiles For This Useful Post: |
05-28-2015, 06:16 | #9 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
If You Cant Find Boot Key Just Open Your Set Solder Rx Tx Gnd By Rj45 Cable Than Go To Pin Out Tab If You Cant Success Post Result .: BR :. ..:: [ S V ] ::.. ..::: MIRACLE TEAM :::.. Br Palash Ahammad
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
05-28-2015, 08:13 | #10 (permalink) | |
No Life Poster Join Date: May 2010 Location: Alwar Age: 47
Member: 1311498 Status: Offline Sonork: 100.1662995 Thanks Meter: 513 | Quote:
Boot Keys 1. Power button 2. Home/Menu key 3. Call key, 4. Camera button (when camera button on phone) 5. 5 key 6. * key 7. # key 8. 0+2 9. 0+2 10. *+# 11.In Touch Phone Mostly Volum Down Key BR, MIRACLE TEAM | |
05-17-2017, 12:51 | #13 (permalink) |
Freak Poster Join Date: Sep 2012 Location: NIGERIA
Member: 1817604 Status: Offline Thanks Meter: 6 | PLEASE HELP ME WITH THIS PLEASE IS NOT DETECTING ANY SPD PHONE I HAVE INSTALLED ALL SPD DRIVERS SAME PROBLEM I HAVE UPDATED AND ALSO CHECKED HERE C:\Program Files\Miracle Box\BOX_Data\Drivers\Mobile Driver....BUT IS EMPTY ONLY NOTPAD AND MIRACLE PIC FOUND PLEASE HELP ME I HAVE DONE ALL I KNOW SAME PROBLEM http://imageshack.com/a/img923/6192/b0Q6kE.jpg |
