05-22-2014, 10:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2009
Member: 1092799 Status: Offline Sonork: 100.1603347 Thanks Meter: 111 | spice mi354 flash done set is fully dead [Problem Solved] spice mi354 firmware write by og flasher after flash done set is fully dead pls suggest me how to recover thanks ======================= Proud to Say you are Mirac Team User _______________________ Waiting for USB Port... Set MTK USB Port (COM27) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: NOR_NEW_0073 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading Size: 0x21000000 Reading infr(Nand)... Done. Definition Applied Waiting for USB Port... Set MTK USB Port (COM27) Please Hold "ON" to connect with the phone... Unstable USB port Definition Applied you can Set Formatting Addr Waiting for USB Port... Set MTK USB Port (COM27) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: NOR_NEW_0073 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Formatting Nand Flash... Format Satrt Addr£º0x17640000, Size: 0x7A00000 Format nand OK Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.84 Update:14-05-04 Firmware Version:1.10 Connected OK. Connecting Internet... You use Latest Miracte Software 1.84 Fuzzy Logic Method is very safe and reliable ! now giving error http://i60.tinypic.com/334oowl.jpg |
05-22-2014, 11:46 | #2 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 42
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,128 | Quote:
Please Do You Read BIN File From Same Working Set Than Write Your Faulty Set Hopefully You Willbe Done. Tested By Me Bro:- Palash Ahammad | |
