08-02-2013, 01:21 | #1 (permalink) |
Product Supporter Join Date: Feb 2012 Location: KB GSM STORE
Member: 1727711 Status: Offline Sonork: 100.1590443 Thanks Meter: 1,331 | Ufs Hwk Update Problem Solution Hi Friends i have seen some users complaint me that they cannot update their new ealge eye box on ufs hwk software solution is already posted in their section FIRST FORGET ALL OLD SETUP THEN REMOVE OR UNINSTALL OLD SETUP FROM PC NOW DOWNLOAD BELOW SETUP NOW OPEN THIS SETUP UFS PANEL
Regards Miracle Team |
The Following 8 Users Say Thank You to .:Abdul-Basit:. For This Useful Post: |
08-02-2013, 11:56 | #2 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478609 Status: Offline Thanks Meter: 1 | HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully. |
The Following User Says Thank You to bittukhan For This Useful Post: |
08-07-2013, 14:44 | #4 (permalink) |
Member: 1727711 Status: Offline Sonork: 100.1590443 Thanks Meter: 1,331 | @ bittukhan @ Hi-Fi Computer Try now server was closed that time Regards |
The Following User Says Thank You to .:Abdul-Basit:. For This Useful Post: |
08-08-2013, 08:46 | #6 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 966792 Status: Offline Sonork: 100.1602610 Thanks Meter: 199 | None Authorised Copy of Software Detected, Reinstall Bad IX: AB1D Failed: 100 Your IP: 123.------------- Support: Account Ok Wrong Instalation, Try to Use [Install] in Software Page |
The Following 2 Users Say Thank You to mayank.gupta For This Useful Post: |
08-08-2013, 16:24 | #8 (permalink) |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | Uninstall old ufsx setup and Driver,,,,,,,,,,,, 100000000000000000000000% Salution here. ist ,,Click Hardware tab ,1 scan Box,,,2 Check box 3Update box ,,,,,,,,,,, Than Click Software Tab,,Check Server 2 Install ,,,,,,,,,,, ok ok ok, Try |
08-15-2013, 07:41 | #11 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Great Pakistan
Member: 101548 Status: Offline Sonork: 100.1611535 Thanks Meter: 210 | before my ufs working good but when i update i got this error.. Account Closed by Admin User Id not Allowed |
The Following User Says Thank You to taimoorkhan For This Useful Post: |
08-16-2013, 12:18 | #12 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1396252 Status: Offline Thanks Meter: 1 | Box: 1 Location: 66 Serial: 76159 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76159 HID: 5DCA5D28416000EE, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Your IP: 119.235.54.179 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 76159 NVML: OK BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 76159 LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76159 HID: 5DCA5D28416000EE, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Connection to server failed. Socket Error # 10060 Connection timed out.(A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.) |
The Following User Says Thank You to naveengod For This Useful Post: |
