04-07-2014, 12:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Romania, Bistrita Age: 70
Member: 85467 Status: Offline Thanks Meter: 104 | HTC Desire no unlock try to read code from HTC Desire and no unlock: how unlock (read code) on this phone? HTC Direct Unlock is Activated Checking Device State... Normal mode Reading phone informations... Reading info ok MODELREAD: Desire MODELREAD2: HTC Desire / bravo MODELDETECTED: BRAVO OS_VERSION: ANDROID 2.2.2 FRG83G FIRMWARE: 2.29.405.14 / 32.49.00.32U_5.11.05.27 BOOT_LOADER: 1.03.0003 HTC_HWID: bravo-129 FLASHID: 5500BCEC KERNEL_VERSION: 2.6.32.15-gf5a401c HTC_CID: HTC__032 HTC_MID: PB9920000 CpuInfo: ARMv7 BRAVO Checking Device State... Normal mode Checking Root Permissions... Sending data to device... Failed to send data Command executed ++ You are NOT ROOT ++ Checking SuperUser if exist... Checking Device State... Normal mode ## Check device screen if SU needs your permission ## Checking SuperUser package... SuperUser package not found Checking Executable SuperUser(bin)... Checking Executable SuperUser(xbin)... Executable SuperUser file not found -- Device is NOT ROOT -- Trying to get temporary Root... Sending Root Exploit #2 ++Please Disable Your AntiVirus++ Executing Exploit... /data/local/tmp/zergRush: not found Starting Daemon server on Kernel Done Checking Root Permissions... Sending data to device... Failed to send data Command executed ++ You are NOT ROOT ++ Failed to root device Checking device infromations... Sending Exploit... Changing permissions.... Running exploit[1]... Reading data... Reading data... Operation Failed Error 21 Elapsed: 52 seconds thx |
04-10-2014, 14:29 | #2 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Russian - Krasnoyarsk
Member: 1798609 Status: Offline Sonork: 100.1620395 Thanks Meter: 2,830 | Quote:
manually root your device and try again | |
04-10-2014, 15:55 | #3 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Nepal,kathmandu
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | yes root mannually your phone then succesfull......unlock @GSMCocktail yes root mannually your phone then succesfull......unlock thanks alot Last edited by .:Abdul-Basit:.; 04-12-2014 at 14:16. Reason: Quote Removed |
