Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Miracle Gsm Cocktail
Old 01-31-2014, 02:29   #1 (permalink)
.:Abdul-Basit:.'s Avatar
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
How To Flash Your HTC Phones With GsmCocktail ( Guide )
Hi Friends ,
I have seen many of friends are stuck flashing HTC Phones stuck on logo & other problems , because of they don't know which file is correct for their phone.
Let me explain you,what you have to do first when you get htc in your shop.
1st of all u need to put your phone in fastboot mode it is simple by pressing volume down + power button your phone will go into hboot mode then pressing power button again you will go in fastboot mode which is show on screen too like show in pic below
now when u go in fastboot mode put cable inside phone and install drivers which is adb drivers u can found drivers easily in gsmcocktail support or download it from here : http://forum.gsmhosting.com/vbb/f754...014-a-1697080/
after installing drivers open HTC Android Tool click read info button
after getting read info u need to focus on 3 things
1st Security is on or off you can see this on fastboot as well
2nd
device country
3rd
main version
if your security is on ( S-ON ) then you need to use this method
you need to make sure both things should be correct for your rom which u want to download from support for flash your phone with gsmcocktail dongle
you can download from shell easily or u can download it from support too
here is tutorial : http://forum.gsmhosting.com/vbb/9725117-post5.html
once you found your correct rom matched with device country cid and main version you will be able to flash your rom .
and if your phone security is off ( S-Off) then you dont have to match both things u can flash it with any rom any main version etc
Note : if you do not found your correct rom matched with device counrty or main version or you found rom like main version is ok but device country is not same then rom will not work so in that case you need to use the cmw method custom rom flashing guide posted below
http://forum.gsmhosting.com/vbb/f754...guide-1746101/
any more questions or further help need i m ready to answer
Best Regards
Abdul Basit ( KBGSMLAB)
GsmCocktail Team
The Following 10 Users Say Thank You to .:Abdul-Basit:. For This Useful Post:
Old 02-02-2014, 07:55   #2 (permalink)
Member: 151584
Sonork: ghauribrothers
Thanks Meter: 39
Salam...
method was find you discribed but how to do (S-off) b4 flshing the fone... jst wanted to ask....????
Old 02-02-2014, 12:55   #3 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
Originally Posted by Bismillah_mob View Post
Salam...
Hi
S-off method is already discussed and if u want to know about particular model of htc s-off let me know details phone model name etc so ill guide u about it more
Best Regards
Abdul Basit ( KBGSMLAB )
The Following 2 Users Say Thank You to .:Abdul-Basit:. For This Useful Post:
Old 03-06-2014, 11:19   #4 (permalink)
Member: 2096526
how to flash
Checking Device Battery
BATTERY-STATUS: GOOD
MID: PC10*****
VERSION-BOOTLOADER: 0.85.0013
VERSION-MAIN: 2.42.405.4
CID: 11111111
Erasing cache partition...
File name: RUU_Vision_Gingerbread_S_HTC_WWE_2.42.405.2_Radio_ 12.56.60.25_26.10.04.03_M_release_199043_signed.zi p
Please Wait...
sending 'zip' (260221 KB)...
Done
writing 'zip'...
writing 'zip'... zip header checking...
zip info parsing...
FAILED (remote: 24 parsing android-info fail)
Elapsed: 55 seconds
Old 04-01-2014, 15:44   #5 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
MID: PC10*****
CID: 11111111
Please Wait...
Done
writing 'zip'...
zip info parsing...
Elapsed: 55 seconds
Hi
change firmware and try again or flash it with ruu
Old 04-22-2014, 13:39   #6 (permalink)
Member: 2111906
Sonork: 1577032
Thanks Meter: 5
htc one m7 hboot 1.56 s-off can ? ? ?
Old 04-22-2014, 14:12   #7 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
Hi
Yes You Can Do S-off With Any Hboot .
Old 04-23-2014, 07:42   #8 (permalink)
Member: 2111906
Sonork: 1577032
Thanks Meter: 5
Wink
Originally Posted by .:Abdul-Basit:. View Post
Hi
can you sho me ? you chak frist then i buy
Old 04-24-2014, 21:11   #9 (permalink)
Member: 881225
Sonork: 100.1678282
Thanks Meter: 80
how to flash htc wildfire hang on htc logo im new user how to flash phone help
Old 05-01-2014, 00:22   #10 (permalink)
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
Hi
read first post guide twice your will find your answer
any further help need post your desire problem making new thread with screen shot of fastboot read info.
Page generated in 0.21767 seconds with 8 queries
