02-15-2013, 13:42 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 49
Member: 83984 Status: Offline Thanks Meter: 25 | iphone 5 sprint no 3g and message |
02-15-2013, 13:44 | #2 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 367030 Status: Offline Thanks Meter: 16 | same problem...........i follow this one but no luck 1) Jaibrake your iPhone 2) Enter iPhone via iFunbox application 3) Delete this files: VAR/Wireless/library/ .plist VAR/Mobile/Library/Carrier Bundle.bundle/ - delete all files from folder 4) Restart iPhone any solution |
02-15-2013, 14:16 | #3 (permalink) | |
Member: 83984 Status: Offline Thanks Meter: 25 | Quote:
02-15-2013, 16:08 | #6 (permalink) |
No Life Poster Join Date: Oct 2012
Member: 1828162 Status: Offline Thanks Meter: 172 | First make sure that your x-sim works on a brand clean Sprint iphone 5 (insert sim card with x-sim, enter 3101200, accept and restart phone. If (after a minute or two phone diaplays waiting for activation, that is OK. After 3-5 minutes phone should display "Could not activate iphone", click Ignore and if you see signall bars and network name - x-sim is OK. Wait for a little while to make sure that your phone has a solid singal. If it fails after a several minutes, that means that your card is not supported (maybe 128k sim card that i've not tested) OK. Now you have working Sprint iphone but without SMS out and 3g network option. That is OK, because Sprint disables those by default (even on unlocked phones). 1. Now, to jailbreak it. Download evasi0n from www.evasi0n.com and do the JB 2. Open Cydia and wait to configure filesystem. Open it again 3. Install SAM from repo.bingner.com in Cydia\sources (of course, you'll have to tap edit/add to add that source in cydia) 4. Open SAM and enable Hactivate option. 5. Download ifunbox (google is your best friend) and run it 6. Click on raw filesystem and open System, Library, CarrierBundles 6. Delete 3 folders: 310120, Sprint_LTE_(...something...) and Sprint_Virgin(...something...) 7. Now back to raw filesystem and open folder var,Wireless,Library. Search for any file that has extension .plist in that folder and ALL of the subfolders and delete it. -Now you have iphone that doesn't know from what network it came from 8. Restart iphone 9. Insert plain sim card without any interposter. As if it is a simfree iphone. Activation screen will not popup because you have jailbreak and SAM installed. Go to setting/carrier and enable manually search for network. If there is no Carrier option, just tick on Airplane mode on and off. There should appear Carrier. 10. When your iphone displays networks available, eject sim card and put in x-sim together with your sim card. Make sure that in Setting/General/About it displays Carrier 14.0 |(as if it is a simfree phone) 11. Open SAM, turn off hactivate option, go to Utilities and tick Atemp activation. Phone should respring and you'll have sms working and 3g (of course turn on Data Roaming option in General/Cellular Data Important note: DO NOT ACCEPT Carrier update from iphone or itunes, or you'll have again Sprint settings which disables SMS and 3G. Best Regards, X-SIM.BIZ Last edited by Bert; 02-15-2013 at 16:37. |
The Following 2 Users Say Thank You to RIPESZ For This Useful Post: |
02-16-2013, 13:53 | #9 (permalink) | |
Junior Member Join Date: Feb 2013
Member: 1881042 Status: Offline Sonork: MADHAA Thanks Meter: 1 | Quote:
02-22-2013, 10:52 | #12 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Ahmedabad
Member: 341402 Status: Offline Thanks Meter: 11 | IT's working on ios 6.1.2 sprint [QUOTE=RIPESZ;9195476]First make sure that your x-sim works on a brand clean Sprint iphone 5 (insert sim card with x-sim, enter 3101200, accept and restart phone. If (after a minute or two phone diaplays waiting for activation, that is OK. After 3-5 minutes phone should display "Could not activate iphone", click Ignore and if you see signall bars and network name - x-sim is OK. Wait for a little while to make sure that your phone has a solid singal. If it fails after a several minutes, that means that your card is not supported (maybe 128k sim card that i've not tested) OK. Now you have working Sprint iphone but without SMS out and 3g network option. That is OK, because Sprint disables those by default (even on unlocked phones). 1. Now, to jailbreak it. Download evasi0n from www.evasi0n.com and do the JB 2. Open Cydia and wait to configure filesystem. Open it again 3. Install SAM from repo.bingner.com in Cydia\sources (of course, you'll have to tap edit/add to add that source in cydia) 4. Open SAM and enable Hactivate option. 5. Download ifunbox (google is your best friend) and run it 6. Click on raw filesystem and open System, Library, CarrierBundles 6. Delete 3 folders: 310120, Sprint_LTE_(...something...) and Sprint_Virgin(...something...) 7. Now back to raw filesystem and open folder var,Wireless,Library. Search for any file that has extension .plist in that folder and ALL of the subfolders and delete it. -Now you have iphone that doesn't know from what network it came from 8. Restart iphone 9. Insert plain sim card without any interposter. As if it is a simfree iphone. Activation screen will not popup because you have jailbreak and SAM installed. Go to setting/carrier and enable manually search for network. If there is no Carrier option, just tick on Airplane mode on and off. There should appear Carrier. 10. When your iphone displays networks available, eject sim card and put in x-sim together with your sim card. Make sure that in Setting/General/About it displays Carrier 14.0 |(as if it is a simfree phone) 11. Open SAM, turn off hactivate option, go to Utilities and tick Atemp activation. Phone should respring and you'll have sms working and 3g (of course turn on Data Roaming option in General/Cellular Data Important note: DO NOT ACCEPT Carrier update from iphone or itunes, or you'll have again Sprint settings which disables SMS and 3G |
The Following User Says Thank You to nishu21611 For This Useful Post: |
