Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff. |
04-15-2004, 14:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | Screenshots Part II Code: Siemens Screenshot --------------------------------------------- (c) Copyright 2004 by ACiD[mrp] (p) Published 2004 by GSM Development Crew www.gsm-dev.com /------------\ /------------\ /---\ /---\ | | | | | | | | | /--------/ | /-------/ | | | | | | | |_______ | | | | | | | | |\ /| | | | /------\ |________ | | | \./ | | | | |__ | | | | | | | | |____| | /--------/ | | | | | | | | | | | | | |____________/ \____________/ |___| |___| D E V E L O P M E N T C R E W http://www.gsm-dev.com (c) 2003, 2004 by ACiD [mrp] powered by www.handyhelpline.com join us at www.gsm-multifund.de/board (english, german) With this program it's possible to take an screenshot from Siemens mobiles. Supported mobiles: ------------------ tested: ME45i v4 --> works S55 --> works M55 --> works, but wrong color palette should work with: C45, S45, ME45, M50, MT50, C55, SL55, C60, ... will not work with: x35, SL42, SL45 and all non Siemens devices like C30, S40, ST55, ST60 BFB Mode: --------- You will need an little patch to work with the BFB mode. It's very easy to write this patch. Have a look at 'bfb patch.txt' to see if an patch is available for your phone and how to write one. Please make shure not only patch the BFB mode, but also the CRC's. If you have not patched the CRC's some phones will show 'wrong software'. Baudrate: --------- Most mobiles needs 57600 Baud to getting into BFB mode. SL45 and x35 needs 19200 Baud but I had no time to test it out. So no support for this mobiles sorry. They are out - dated. Color Palette: -------------- For 4096 color displays there is an wrong palette till now. If you like to make an right palette please send me an mail ([email protected]) I will not make one in next future. Some more: ---------- - in BFB mode it's not possible to copy screen before doing screenshot. If you want to make an faster screenshot and an screenshot from unstable or animated screen you have to use the AT+CGSN Debugger. - phone have to be on during all operations - If you want to change COM Port parity, stopbit or databit, add an INI entry named: AdvancedMode=1 in section "COM Port". - please visit my sponsor www.handhelpline.com without him I wouldn't have any mobile to test and write software. - please make shure you are NOT R.G.R.Bergs. If so you are NOT allowed to use this program and ANY other gsm-dev programs. - my very best greetings goes out to: RizaPN, SkyLord, SiNgle, mamaich, Chaos, Cluni, exr Schiffner, Braindead, b@iLLi, holg, vikado77, gurgy, dr. ON, REDKIN, SL45_6688i, DarkBear, cool_lang, spinkilla, Andi_HUYVU, mic.kan, dspmobile, NIXS, GIROSAVO, MULTIFUND, handy, holg all from gsm-multifund, handyhacking, gsm-city and of course <CB> Last edited by Acidmrp; 04-22-2004 at 18:26. |
04-19-2004, 17:34 | #3 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | problem solved in icq: change the ini File: [Display Typ] 22 = 4096 should be [Display Typ] 22 = 256 for your phone. Your phone has an 4096 Colors display. You can save picture by clicking right on picture and press "Save as..." |
04-20-2004, 10:38 | #4 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | new version: v1.0.0.6 - added 4096 color palette (thx to Terminal2004) - changed display color handling because some S55 have 4096 color displays - some changes in GUI |
04-21-2004, 13:56 | #5 (permalink) |
Junior Member Join Date: Apr 2004
Member: 60764 Status: Offline Thanks Meter: 0 | Acidmrp, thx for a soft. But for me with С55 does not work. I'm generate and install patch with "fbytes": ; С55 (24) ; open BFB 105EF6: 50 3A But Screenshots 1.0.0.8 writes: Try #0 Mobile in BFB mode now. Open BFB Patch not installed. Please install this patch to continue. BFB mode closed Baudrate restored. How to solve this problem? Type of the phone and SW version in the program is visible. PS Excuse for bad English. |
04-22-2004, 11:36 | #6 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | v1.0.2.0 - now using the 4096 palette from SPC2 found works perfect now - make screenshot even if display type is unknown @Vlog this is an problem from BFB Patch. Sorry don't have an C55 to write another one. |
04-27-2004, 15:37 | #10 (permalink) | |
Member: 60764 Status: Offline Thanks Meter: 0 | Quote:
04-28-2004, 04:31 | #11 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | you have to use AT+CGSN Debugger for making C55 screenshot. The C55 do not answer to openBFB mode even with openBFB Port. I think there is some more protection or other protocol. So just make an C55 Playfield entry for AT+CGSN Debugger and use this Screenshot function. Here the Patch: ; Firmware : C55 v24 ; Author : original by RizaPN improved by Chaos, SiNgle, Dr.On ; mamaich ported to C55v24 by ACiD[mrp] ; yeahhh team work ; Homepage: www.gsm-dev.com ;---- New block. Segment address: 430000 -------- 430258: 0889C100 96ACE300 ;---- New block. Segment address: E30000 -------- 63AC00: FFFFFFFFFFFFFFFF E004BB029DFECB00 63AC08: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49992827F230008D0C47F20A008D06 63AC18: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182 63AC28: FFFFFFFFFFFF CB001F88CB00 63AC2E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182 63AC3E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997 63AC4E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0 63AC5E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDAC38E1F080698C0 63AC6E: FFFFFFFFFFFFFFFF 98F098E09850CB00 63AC76: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4 63AC86: FFFF CB00 63AC88: FFFFFFFF 998C7C44 63AC8C: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00 63AC96: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC28ACEF084F095DC49993827F32A00 63ACA6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FAC10889BBA9F0F4BBA7F0E44930 63ACB6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D4E27F312002D18E6FD0D0A 63ACC6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC 63ACD6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D53 63ACE6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D51DC4FB98E08E10DFA88408850 63ACF6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D088E088F0E00CE00DE00EE00F 63AD06: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBC28D1A70C4BBBF8D175C8C70C4BBBB 63AD16: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D1370D4BBB88D105C8D70D4BBB48D0C 63AD26: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70E4BBB18D095C8E70E4BBAD8D0570F4 63AD36: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBAA8D025C8F70F498509840DAE390AD 63AD46: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E4BB96F0E5BB9498D098C098509840 63AD56: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D1A26F04000F020BB968D03B9820821 63AD66: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0DFB2020A758A7A708E12D0BF010F0DE 63AD76: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C2DC4F998D498D3DF528C13DFACA00 63AD86: FFFFFFFFFFFFFFFFFFFF 76AC06F04000FAC292C5 63AD90: FFFFFFFFFFFF ECF5ECF4DB00 |
04-29-2004, 10:47 | #12 (permalink) |
Member: 60764 Status: Offline Thanks Meter: 0 | TXH ACiD!!! Now AT+CGSN Debugger works with C55! Addition for С55 in Playfield.ini: [C55v24] enabled=1 ScreenAddressA = 164592 SaveScreenA = 327680 ScreenAddressB = 0 SaveScreenB = 0 ScreenSize = 1040 MemCopyAddress = DC3AD6 PlaySoundAddress = 948F9E RunInRAMAddress = 00C210 IlluminationOn = 9287A6 IlluminationOff = 9287AE The Java-screen has not made, there was no time. Somebody can will make and will write. Only in the program the screen - 101х80, and at С55 101х64. |
04-30-2004, 08:09 | #14 (permalink) |
Member: 60764 Status: Offline Thanks Meter: 0 | More correct addition for C55 in file Playfield.ini: [C55v24] enabled=1 ScreenAddressA = 164592 SaveScreenA = 4096 ScreenAddressB = 394024 SaveScreenB = 4096 ScreenSize = 1040 MemCopyAddress = DC3AD6 PlaySoundAddress = 948F9E RunInRAMAddress = 00C210 IlluminationOn = 9287A6 IlluminationOff = 9287AE Many thanks to Sinclair for the help! Last edited by Vlog; 04-30-2004 at 08:20. |
11-22-2005, 20:13 | #15 (permalink) |
Junior Member Join Date: Nov 2005
Member: 202093 Status: Offline Thanks Meter: 0 | Siemens screenshot for c56 v29 Hello all, this is my first message in this forum. Iīve been having the same problem Vlog had. I got the Siemens Screenshot program and tried it with my c56 v29 with no positive result. I see this is a bit too late to ask for this, but i havenīt found any at-cgsn patch for this firmware. Is Acid still overthere to help? plz... |
MSS4 Part II | legija | Motorola P2k | 1 | 09-15-2005 22:41 |
Do we really need free codes section Part II? | legija | Off Topic Zone | 105 | 03-17-2004 09:28 |
