Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-27-2016, 08:40 | #1 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2458927 Status: Offline Thanks Meter: 1 | GT-I9300 - USB Device not recognized Since yesterday, i'm trying to unlock one Galaxy S3 I9300, but keeps saying "USB Device not recognized" In download mode phone is OK, connecting and everything, but i cannot unlock it in download mode. As soon as i turn the phone on, that error pops up. Charging port replaced, different cables, different usb ports = same results... I've flashed the phone , worked like a charm (in download mode), but cannot unlock it. Any ideas? |
07-27-2016, 08:51 | #2 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Dharmapuri,Tamilnadu
Member: 1343981 Status: Offline Thanks Meter: 30 | Dear bro try below steps dia *#0808# then select mtp+adb then post your result Regards SatcomSingaram Quote:
The Following 3 Users Say Thank You to SatcomSingaram For This Useful Post: |
10-27-2018, 10:40 | #5 (permalink) |
Junior Member Join Date: Jun 2015 Location: distric-kushinagar,u,p,india
Member: 2416951 Status: Offline Sonork: 100:41718 Thanks Meter: 0 | hi.... samsung gt n7100 imei repair error REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: GT-N7100 Software version: 30.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-N7100 Android version: 4.4.2 Product code: Not Active Phone version: N7100DDUFND1 PDA version: N7100XXUFND3 CSC version: N7100ODDFND2 CSC country code: India CSC sales code: INU HW version: Unknown Phone SN: RF1D42NZ8QB Modem board: XMM6262 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... error Done with Samsung Tool PRO v.30.4 plz help me....... |
