Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-31-2019, 09:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: ON THE BEACH
Member: 1487630 Status: Offline Sonork: 100.1621007 Thanks Meter: 43 | A750F A7(2018) could not do normal boot, invalid kernel length" today i received a a750f which is only shows "could not do normal boot,invalid kernel length" so i try to flash with latest pie version but facing "no pit partition" error can any one provide 'pit' file???? pls |
The Following User Says Thank You to vassu_bar For This Useful Post: |
07-20-2019, 19:03 | #4 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Iran
Member: 299773 Status: Offline Thanks Meter: 14 | File analysis... OK Total file size: 0x89F9BD00 (2207 Mb) Searching USB Flash interface... COM4 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.36.8 https://pasteboard.co/IoSWSIY.jpg |
The Following User Says Thank You to armin666 For This Useful Post: |
10-12-2019, 17:10 | #9 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Online Thanks Meter: 432 | Quote:
If a custom recovery TWRP is flashed and then after twrp you turn OEM ON, won't you get this message? OEM ON with custom binary flashed is a BIG no no. Flash same binary firmware or latter one to get phone working? | |
10-13-2019, 09:24 | #12 (permalink) | |
Have you try with the very latest version of odin? odin3-v3-13-3 download Sometimes using box program may not work, as the odin protocol may not be updated and not flash correctly. | |
01-10-2021, 11:34 | #15 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 437 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A750F Software version: 41.11 File analysis... OK Total file size: 0x17313559F (5937 Mb) Searching USB Flash interface... COM13 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.41.11 |
