Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-15-2020, 13:46 | #16 (permalink) |
Junior Member Join Date: Aug 2007
Member: 562917 Status: Offline Thanks Meter: 4 | Ok, so I bought a phone with the exact same problem, its a Samsung Galaxy A70 (A705FN) KG locked, when I reset the phone and go through the setup wizard, after I finish the screen gets locked and it asks for antitheft pin. This is a strange problem, I checked the IMEI and it appears as CLEAN on all imei checking websites............ I really don't understand how this Knox Guard works. ANYWAY here's the interesting part, I found a way which I can explain to you guys on how to get into SETTINGS and even Play Store and Galaxy Store so I am able to download and install apps... I tried to connect the phone to PC but Smart Switch says USB file transfer not allowed. That's because I haven't completed Setup Wizard. I found a way to bypass it but its not completed and the phone isn't showing me the notification for USB file transfer ALLOW or DENY. Tapping on BUILD NUMBER does nothing, it does not enable developer options as that would have been of help for installing a custom ROM. I think its because I haven't completed setup wizard. The goal is obviously to install a custom ROM and after that the phone will surely function perfectly. I can install apps from the stores, or I can even install apps from outside of store by sending them to this locked phone through bluetooth. Now the question is what apps can I install to fix this phone? Apps that would somehow allow USB file transfer, apps that would skip Setup Wizard, apps that would enable developer options...? Help me with these apps, tell me what apps to install in order to fix this phone and I will tell you the secret how you can get into settings while your phone is in this antitheft situation. Or maybe there another fix? All I can say is that I have access to settings and I will teach you all how after we fix my phone first. |
11-06-2020, 15:40 | #17 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Pampas Gaúcho tchę Age: 48
Member: 116335 Status: Offline Thanks Meter: 17 | Quote:
("I found a way to bypass it") how did you bypass it? Have you tried disable administrator of phone? | |
11-09-2022, 12:43 | #25 (permalink) | |
No Life Poster Join Date: Sep 1999 Location: Europe Age: 51
Member: 487 Status: Offline Thanks Meter: 65 | Quote:
If you dont want help, dont write too much things blablabla. this community is to help each other, not if you give this i give you that. | |
12-04-2022, 16:17 | #26 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2815350 Status: Offline Thanks Meter: 5 | As someone pointed out on the first page, thatīs indeed a leased phone, has his hardware tainted as a result of that the states are: Periodic Lock (Usually Prenormal Status) , Then Overdue and finally Guilty. How to tell if you are a technican might be important. If the device shows a screen on notifications saying that some payment or lock is about to be performed if x ammount of time for payment is not met means itīs on overdue. Later it will start showing a lock screen that you can dissmiss and then it will lock. Do note that those are "Hardware Tainted" since they come out to the buyer so.. thatīs a way to tell. As for the original poster i would replace the motherboard at this stage keep in mind thatīs voided + locked and flashed the integrity of that phone is mostly broken at this stage, even if you can make it boot somehow the best shot would be some custom gsi if thatīs an option. Returning to official firmware will end on integrity checks failing and the device locking. Sadly the solution for his particular case is probably not possible for that motherboard at the stage it is now. Hope it helps sometimes a bit of insight about the issue is also helpful. |
