Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-19-2022, 12:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | Alliance shield without adb.... I have one A40 SM-A405FNXXS4CUL2 that i downgrade to SM-A405FNXXS4CUH2 and successfully restore Samsung backup. Unfortunately service mode in Alliance does not contain all the usual options MTP/ADB..... Have please a look at attached pictures to see. Any idea or hint? When I get to usb settings I got just that Silent Log. Regards |
02-19-2022, 19:17 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Device have Knox? When you setup Alince shield it’s show Knox? If yes tick on that then retry same If phone not have Knox you can’t bypass 11 version If device have 10 android version can try set pattern - |
02-19-2022, 19:17 | #3 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Device have Knox? When you setup Alince shield it’s show Knox? If yes tick on that then retry same If phone not have Knox you can’t bypass 11 version If device have 10 android version can try set pattern - Duble post please delete anyone Last edited by pradeep_kus; 02-19-2022 at 19:18. Reason: Duble post internet issue |
02-20-2022, 00:13 | #4 (permalink) | |
Member: 266339 Status: Offline Thanks Meter: 99 | Quote:
Yes it has Knox, please see attached pictures. Knox is activated too. I do not know what is wrong. Regards | |
02-20-2022, 12:37 | #5 (permalink) |
Member: 266339 Status: Offline Thanks Meter: 99 | Done ! Hello mates, I get it finally done. The issue was: in the tutorial I followed, in the part activities (alliance shield x), one has to use the search option and input again Service mode. The result of the search are many lines with service mode options, from which, I choose the USB settings. The solution is: under activities, just scroll down until "Service mode......USB Settings" Regards |
